Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660
How do I add MP3s to my Garmin? I cannot seem to locate the correct prgram to transfer from.
When you connect your Garmin to your PC (using the USB lead)you should see the Garmin as a removable drive. Just use the file manager (Windows Explorer) to transfer the mp3 files from your pc to your Garmin MP3 directory.
Posted on Jan 23, 2008
My garmin nuvi 660 is frozen . how can I do?
Reset the nuvi 660:
1 Disconnect from external power.
2 Flip antenna up.
3 Locate and press small button labeled "RESET" in the antenna recess on rear of nuvi 660.
4 Connect to external power source.
The nuvi will reset, power up and operate normally. If this was helpful, please rate it 4 thumbs up - thanks & good luck!
Sep 20, 2011 | Garmin Nuvi 660 GPS Receiver
How can I transfer Favorite Locations from a Nuvi 660 to a 1350
Jan 21, 2011 | Garmin nuvi 1300 Car GPS Receiver
How do I load itunes songs to Garmin Nuvi 755T?
Songs in iTunes are in the AAC format. The Garmin only recognizes MP3s. You would have to convert the files before you could transfer them.
Aug 21, 2010 | Garmin Nuvi 660 GPS Receiver
My Garmin 660 will no longer plot a destination...
Have you loaded a lot of JPGs or MP3s on the internal memory? If so, you have reduced the amount of memory available to the 660's OS. Not sure if the 660 stores calculated routes directly to the internal flash memory, but it is very likely, since it keeps your route when you power it down.
To unload the internal memory, consider buying an SD card - they are cheap right now. As a matter of fact, I just ordered an 8GB SD card for my 660 from Amazon for $13. The 4GB and 2GB cards are available for about $7 and $3 respectively. Drrrrrt cheap!
You can access the internal memory of the 660 on your computer with the USB cable you got with the 660. The two folders to focus on are the JPEG and MP3 folders. Simply copy these folders' contents to the root directory of the SD card, and then go into each folder in the GPS memory and delete the MP3s and JPEGs you added - should work better. The 660 will recognize the files on the card if left in folders named identically to the folders in the internal memory.
If you didn't add any content to the internal memory, that is a different issue altogether, probably something to discuss with Garmin. Could be as simple as upgrading the firmware. Make sure you select the correct version though, or it could be a fancy brick! Go here for the nuvi 660:
Good luck, and I hope this helped!
Jan 05, 2009 | Garmin Nuvi 660 GPS Receiver
Stop transfering voice from Sony Ericson P910i and Garmin Nuvi 660
Can you update the firmware on your unit
my k800i sony phone had a problem synchronising and would freeze, then one day the nuvi 660 updated the firmware by itself and has been fine since, only problem being the volume, a bit low when trying to contest with large diesel engine, onboard speaker keen to distort over 80% volume
Feb 08, 2008 | Garmin Nuvi 660 GPS Receiver
Deleting MP3's
yes you can but you have to disconnect your device from the computer.
Turn on GPS for few seconds and turn off . Back to your computer connect the usb m, go to GARMIN FILES , MP3S and delete the songs. You should be able , i just did it.
Best regards
Jan 03, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 MP3 files
No program , your 660 read only MP3 , but did you try with WINDOWS it should work nicely.
Contatc GARMIN and mentionned if you can transfert with MAC.
Best regards
Jan 01, 2008 | Garmin Nuvi 660 GPS Receiver
Deleted MP3 files still play on my Nuvi 660.
Go to the GARMIN M3U file , open it and do what you want .Transfer, delete , copy and so so....
Dec 23, 2007 | Garmin Nuvi 660 GPS Receiver
Someone changed my pin on nuvi 660
It can't be reset without entering the correct PIN or driving to the security location. Failing this, the unit must be sent back to Garmin.
Oct 31, 2007 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 MapSource
You cannot replace American maps with European maps.  Garmin does this in order to protect the European retailers.  The European SD card eliminates the need to load the maps into the 660, however, if you need to use the card slot to store extra data such as MP3s then you might be better off buying the 670.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
