Question about Kirby G5 Bagged Upright Vacuum
Oreck belts keep coming off
I have an oreck XL upright and the belts keep coming off. I have cleaned it througly inside & made sure the brushroller was cleaned well. I did notice on the side of the brushroller where the belt goes on to is a little worn could this be the problem? Please help I cant keep going through belts every 5 minutes ( and I mean that literally) it's becoming very costly. Do you think a new roller brush would help?
  • mismissy69 Jan 24, 2008
    Actually I couldn't wait any longer I took it to the dealerr and he fixed it for 60 bucks. The fan housing was broken which loosened everything up and was causing the belt to come off. So he fixed that problem, cleaned up my vac real good (it' looks like new :)) so im satified. Thank you for all your help
  • Anonymous Jun 05, 2008
    bissell revolution bagless vac, belt keeps coming off, does not break. There seems to be a "rough ridge " could this be the cause of problem?
  • 3 Answers
For orecks it is usually the fan housing has loosened everything. your belt will slip. if your vac is under warranty, then fixing should be free. if not, it is about $60
Posted on Jul 04, 2008
  • 1,673 Answers
If the pulley on the brush roll is worn, then I would replace the brushroll. Look at the ends where the brush roll sits in to make sure the casing hasn't over heated and not holding the brush in place. Also make sure the motor is shifting and causing the belt to come off. Another is if you are catching a rug or towel, that also will cause the belt to come off. I am assuming you using a new belt and not a worn one. After only a short time, belts stretch and need to be replaced.
Posted on Jan 22, 2008
My Oreck XL 21 stopped self perpelling, what so I need to replace or fix?
There is a small drive belt that turns the wheal that may need replacing open the drive belt compartment and replace like the brush belt. Turn the vacuum upside down to take out the screws it helps keep things in place.
Dec 26, 2012 | Oreck XL Ultra Bagged Upright Vacuum
Roller on upright vacuum is not spinning so vacuum is not picking up dirt
Any time that a vacuum's roller brush stops spinning, this means that your belt has either stretched so much that it's fallen off of the motor, or that your belt has broken.
Here's a very helpful video on how you can replace the belt on your Oreck. This will give you step by step instructions on the belt change.
If you need to purchase a new belt, here's a direct link to a 3 pk. of belts that are used on your Oreck XL upright on our website:
I hope that this video repair was helpful to you! Please be sure to rate my repair helpful by clicking the thumbs up icons in the top of this repair page.
Thank you,
Chris J.
Apr 05, 2010 | Oreck XL2200 Bagged Upright Vacuum
My oreck XL7 smells when it's on. Smells as if it's the motor. Had the Oreck for 4 years but hardly used it?
The smell is probably from the belt. When they are worn and stretched they can start to smell. You can get replacement belts for your model here:
Oreck XL7 Replacement Belts
Nov 10, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL hard to push
yes. it might be broken. you will need to remove the 5 screw on the bottom and see if the belt is burned. it more that likly is.
Oct 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck Vacuum cleaner keeps burning up belts. I
I am having the same trouble. I bought the vacuum new in October 2007 when my wife and I purchased a newly constructed home. Since it is only two of us, she only has to vacuum once a month. I have taken it in three different times and get the same story. It needed a new belt. Mine has white smoke coming out of it and smells like burning rubber. I contacted Oreck and got no results. They refused to let me discuss this with Dave Oreck, stating that he nevers talks with customers! Gary Neeble
Jun 05, 2009 | Oreck XL2000 Bagged Upright Vacuum
I am not sure how o install a new belt on my oreck vacumm, can't
here is the insturctions (copy and paste in your address bar)
Feb 02, 2009 | Oreck XL Ultra Bagged Upright Vacuum
The belt on my oreck xl keep breaking
the brush roller is siezing up on you.try to take the brush roller out and clean it real good .pull the ends off and clean them to things get caught up and wrapped around them and keep them from turning.before you put the new belt on clean the motor shaft .usually when a belt breaks it leaves burnt rubber on the shaft .if you don't clean it the new belt won't last long.please leave feedback.i hope i was some help to you...pete
Dec 26, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck 9100C Vac
Oreck 9100C Vac
Posted by thecleaner on Jun 04, 2008
How to I replace both belt and brush correctly.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL 9100C Ultra Bagged Upright Vacuum. The best way to install the belt is to put the belt on the brushroll 1st and then install the brushroll, the brushroll has marking on the top and the bottom of the bearings stating NEW or USED / OLD and install them identical on both sides and then use a belt puller to stretch it onto the motor pulley. The best place to get instructions on how to install the belt and brushroll is the owner’s manual and an owner’s manual is from the Oreck Factory of which I will supply for you listed below or you can download the owner’s manual from the Oreck Website. . I would check with your local Oreck dealer or vacuum dealer in your area to see what is going on. This is most unusual for this to happen. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 04, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
May 08, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
2,284 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
