Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Verbatim 1G flash
Just went to use my red verbatim flash stick...and nothing. The computer does not even indicate that I have anything in the USB slot!
Can info from these be retrieved? Can it be sent somewhere...or are there people that know how to pull info.
Do these thing usually die, without ANY indication !?!?
Important info on it for both work and church...
[email protected]
  • JOJO5 Jan 22, 2008
    this is my husbands baby...I would believe it got warn out for using it....looks as good as the day he bought it! BUT, it is only a piece of equipment...can not see the insides. ANd it does not work in any of our computers...the usb slot I put it in, is one I unplugged my sons Ipod out of...so I know that the usb slot works.
  • Anonymous Feb 14, 2008
    Same brand flashdrive, but mine is a 4gb "Store and Go" and same problem, EXCEPT mine works on both Vistas AND XP at home, but won't work on XP based computers at work. What could be the problem???
    Scholar:
  • 68 Answers
I expect you have tried something else in the USB?
Look at the contacts is all I can suggest.
Could be an internal fracture from rough handling.
Posted on Jan 22, 2008
6ya staff
SOURCE:
I have a small red Vernatin USB memory stick and forgot my pass word ! what can I do to get back the content ?
Always backup your files from the USB flash drive to a computer, since these removable drives will always either break, get lost, or get stolen. Sometimes a flash drive will prompt you for a password and there will be an option for giving a HINT. Click on this option and see if you left a hint on the drive. Passwords are there to prevent theives from stealing your personal information and data. There are supposedly applications that can read protected files without the password, do a search on the Internet for one of these.
Feb 28, 2013 | Verbatim CORPORATION 94933 USB 2.1GB...
Hi i cannot access my verbatim flash stick. It asks me to format the flash stick but i try to it fails to format can you give me some idea as to fixing this problem pls
I hope your Jump Drive did not get formatted - because all your files would be lost.
You could try this:
Go to "My Computer" and right click on the drive letter for the Verbatim Jump Drive.
Select "Properties"
Click on the "tools" tab and select "check now".
This will check your Jump Drive for problems.
Feb 09, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
I have a verbatim 4gb micro with a write protect error. I cannot delete the files, add more files or format the stick. Regards Mano
It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Jan 06, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
Verbatim 8GB Store-an-go just went dead between uses. Computer does not even register a drive. Is this a loose connection.
have you tried it on another computer? There really are not connectors to get "loose" but unfortunately sometimes the drives do die. I would try is on another computer (windows XP or newer)
If it does not show up on another computer than chalk it up to experience. There are restoration services but they are very pricey. If you pursue this expect to pay $300.00 plus for recovery.
Sorry for your loss.
I’m happy to help further over the phone at https://www.6ya.com/expert/thomas_b83e841f114394f4
Nov 29, 2010 | Verbatim ® Store `n` Go USB Flash Drive,...
I cant format or put data on my Verbatim Memory stick disk is write protected, and it appears the following pop-up screen Verbatim Memory stick disk is write protected so please provide me with...
Some Verbatims have a write protection switch on its side - make sure it's not activated. Then open the properties of the stick in My Computer. If in there the stick isn't set as read only then it has died - there's nothing more you can do to save it. Junk it and get a new one.
Sep 06, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
I have formatted an Verbatim Memory stick, how can I install it again?
Contact Verbatim for a solution, these USB flash drives have lifetime warranties.
Sep 05, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
My Verbatim 4gig store and go usb stick in stuck in RAW Format
right click my computer, manage. go to disk management and delete any volumes on the flash and set back to basic disk if it's dynamic. format fat 32
Mar 14, 2010 | Verbatim STORE-N-GO (95312) 8 GB Hard...
I have a 1G flash drive and when i moved the items i had put on it into the trash it now says there is nothing on the drive, but also says i only have 538 mg of free space. how do i attain my full 1G of...
This can be a caused by a virus or something so this thing that you can try is to format the flash drive , Connect the flash drive to your computer then format it that should clean the falsh drive and hopefully it will be back to its original size..
Hope that helps..........
Sep 08, 2008 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My windows 98 dell dimension 7500cx will not recognize my verbatim 256 mb memory stick
windows 98 need special driver from usb memory stick manufacturer.
if they dont have it then its not a compatible model for win 9x.
what i have done in prior is if high speed internet is saving it to online drive storage free website like xdrive.com if u have aim account youre ready to use it or others like yahoo mail yourself the files then retrieve in other pc.
Jul 30, 2008 | Electronics - Others
Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
144 people viewed this question
Top Verbatim Computers & Internet Experts
gggg
Don Hart
Duncan Mutch
Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
