Question about Uniden BC72XLT Handheld Scanner
Need to lockout a channel
I have no instructions.
Alo kimse yokmu burda turkce bilen bilmiyom iste bu yabancilarin dillerini be zorlami yaniiii bilmiyommmmmmm
Posted on Jan 22, 2008
Stuck in lockout mode
radio shack pro 97 scanning receiver,
Jul 17, 2012 | Uniden BC60XLT-1 Handheld Scanner
How do I unlock my scanner?
Channel Lockout You can lock out a channel so it is not scanned. Channel Lockout does not erase the frequency from the channel. You can lock out up to 50 channels, including the Priority channel.
Lockout information is retained in the memory when the scanner is turned off.To Lock out a Channel
Example: Suppose you want to lock out Channel 2 because it stops on transmissions you don't want to hear.Press LOCKOUT when the scanner stops on Channel 2.The scanner locks out Channel 2, Then it immediately advances to the next channel that is not locked out, and resumes scanning.In the Manual mode, press LOCKOUT to lock out the displayed channel. Pressing LOCKOUT does not advance to the next channel in Manual mode.L/O appears in the display to indicate the displayed channel is locked out.Whenever you want to search for channels that are locked out, press MANUAL repeatedly to go through all 50 channels. If a channel is locked out, L/O
appears in the display.Restore a Locked Out Channel To unlock a channel so that it can be monitored during scanning:1. Press MANUAL repeatedly to find the locked out channel.2. Press LOCKOUT again to unlock the displayed channel. L/O no longer appears in the display.Restore All Locked Out Channel To unlock all channels, you must be in the Manual Mode.1. Press MANUAL.
2. Press and hold LOCKOUT to unlock all channels. The L/O indicator goes out on any channel previously locked out.
Sep 18, 2011 | Uniden BC248CLT Base Scanner
I have a pro92,when I press scan it says all channels locked.How do I unlock all channels?
hi glad to be of help follow the following instructions
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.
goodluck
Mar 22, 2011 | Radio Shack Pro-95 Handheld Scanner
PROGRAM AFTER ALL LOCKOUT OF ALL CHANNELS ON A BC60XLT-1 SCANNER
With the channel display showing 000.0000 you may be able to program a new frequency into it, and the new program will release the lockout. Have you tried the normal programming for any channels?
Bill B
Apr 08, 2010 | Uniden BC60XLT-1 Handheld Scanner
Bearcat scanner lockout on and i want it off
You didn't provide a model number, so this response is a little generic and applies mainly to late model Bearcats. To release an individual programmed channel from lockout, stop the scanner on that channel (select and press MANUAL) then press the Lockout (L/O) key. Any unprogrammed channel, displaying 000.0000, will show as locked out. Programming a frequency into it automatically releases the lockout. If all channels are showing as locked out you may need to reset the scanner. The reset procedure varies my model, so I'll need the model number to describe the steps.
Bill B
Mar 07, 2010 | Uniden Radio Communications
Can't unlock channels. i push func + lockout but nothing happens
To remove lockout on all channels, do the following:
Press scan
Turn on all banks that you want to clear lockout on.
Press hold.
Press func
Press AND HOLD L/O until the radio beeps twice.
Feb 24, 2010 | Uniden BC92XLT Handheld Scanner
Hi i have a regency D300 thrity channel scanner and i need to no how th lock out the weather band channel
put it in manual mode and scroll to the desired frequency that you want to lockout. You should be able to just press the lockout button while in manual mode and it will lockout this channel. Then just simply press resume or scan and it should be resolved.
Jan 21, 2010 | Uniden BC72XLT Handheld Scanner
Lost manual and cannot program scanner bc145xl
Try these instructions from Wiki.answers
Turn on unit.
Press MANUAL button.
Press MANUAL button again to select the channel you want to program. Note the channel in the display. If there is a hyphenated symbol in the upper left corner the channel has been locked out. Press the LOCKOUT button once to remove the symbol or press the LOCKOUT button to lock a channel out. To find out if there is a frequency programed into that channel, press the PREVIEW button. Each digit of the frequency that is stored in memory will be displayed in the LED display. To program a new frequency into that channel, simply press the digits of the frequency you want, including the decimal point. Press the "E" keypad key to enter it into memory. If you get a "E" displayed in the LED display, the frequency was entered wrong, is not a valid frequency or is out of range for the scanner. Last but least, the scanner is not working properly. If the channel is active, (communications going over it) set SQUELCH to higher number, until you hear the communications or just noise. To set the SQUELCH, select a channel that has only noise and turn it down to the point the noise disappears. You make have to readjust it to your liking. Once you have the channels programed you can select the SCAN button to listen to all the channels or select the MANUAL button to listen to just one channel. If there are channels that you don't want to hear during the scan mode, go to MANUAL and select the channel you don't want to hear and press LOCKOUT button. Then press SCAN again it will only scan channels you want to hear.
Hope this helps.
Sep 07, 2009 | Radio Communications
Uniden bc95xlt scanner LOCKOUT REMOVAL
To remove the lockout from a channel, manually select the channel, then press Func + L/O.
L/O disappears.
To unlock all channels in the banks that are turned on, press Hold to stop scanning, then press Func
and press and hold L/O until the scanner beeps twice.
Dec 02, 2008 | Radio Communications
Channel lockout on Regency D300 scanner
While in SCAN mode, enter the number of the channel you want to lockout. To re-activate it, enter the channel number again.
Oct 30, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
49 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
