For a manual code search and entry:
1. Turn on the component
2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL)
The illuminated on-off key turns on and stays on
3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on.
5. Release both keys. The illuminated ON-OFF key remains on
6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.)
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved.
8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed.
Try this too:
In step 6, instead of pressing the on/off button, press the Play button. The on/off button will blink several times as a chunk of codes are sent at a time. If your component turns off, press the Reverse button (slowly) until your component turns back on, then press Stop to save the code.
Basically this does the same thing, but it goes through the codes...ten at a time, I believe. The only time you're going through them one at a time is when you are pressing the reverse key.
SOURCE: Jensen JER-422
Manual:
http://157.254.235.130/public/IBJER422REVA.pdf
Codes:
http://157.254.235.130/public/IBR53M1CODESREVC.pdf
Hope that helps!
SOURCE: need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
SOURCE: lost programming codes to Jensen jer- 422 universal remote.
1030, 1035, and 1191 are the codes for orion tv
SOURCE: need codes for jensen JER 422 remote.
Go to this webpage:
http://www.thomsonnetwork.com/EN/Public/InstructionBook/IBVeritySearch.htm
In the search box enter your model number as JER422 and it will take you to the pdf for both the instruction manual and the codes.
SOURCE: I need the tv codes for a Jensen JER 422 remote
Here you go try these one is sure to be the one you need
Tos iba 0 1 5 4 ,0 1 5 6 ,0 0 6 0 ,1 2 5 6
Please rate my help++++Thanks for using FIXYA
