Question about Canon PowerShot S3 IS Digital Camera
Does this mean the batteries are not strong enough
The red indicator light is on and the camera would not switch on. I replaced the batteries with no effect. I removed and replaced the memory card with no effect - what next?
  • 2,427 Answers
If nick's suggestion fails,
1.)remove the memory card
2.) connect the camera to your computer using the usb cable
3.) click start / computer
4.)your camera will show up there as a removable device
5.)right click it and dlick format
6.)select full format and click format
7.)try it now and let us know what happens
Posted on Jan 22, 2008
    Genius:
  • 1,067 Answers
Is lens stuck give ita slight help twisting open
  • nick helpap
    nick helpap Jan 22, 2008
    will it power on with no sd card bateries new one fully charged
Camera won't charge red light is on but the green light doesn't come on . What is my problem ? Could it be the battery
hi Kenny.
With most cameras, an amber, yellow, or red light indicates a battery that's currently charging. A blue or green light usually means the battery is charged. A blinking light sometimes indicates a charging error; other times, it indicates a battery that is still charging.or faulty battery.
have you tried,take the battery out and then put it back in?.
make sure the battery is seated.and its making a good contact.
Dec 01, 2017 | Green Cameras
My camera won't take pictures with the flash on and when i try the red light just blinks. only takes pictures with no flash.
When your flash light (I mean the part that gives the flash) or the capacitor that stores the power for the flash are defect. you won't see a flash. When a red light comes on, when actually the flash should fire, the most likely the capacitor is defect. The electronics sensed it could not reach the voltage needed to fire the flash.
It also could mean your battery can't deliver enough to charge the capacitor, but is that was the case the battery indicator should tell you.
Jan 20, 2014 | Nikon COOLPIX S230 Digital Camera
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Vivicam 8025 what does the MSDC screen mean while charging
The MSDC indicates that the camera has recognized it's connected to a computer.
The red light indicates that the camera's battery is charging.
Aug 03, 2012 | Vivitar ViviCam 8025 Digital Camera
Screen shows battery with red line through it,, what do i do?
HI. The red line is an indication of a defective battery. This defective cell cannot hold a charge strong enough to power your phone properly. The necessary actions are to replace the battery with a new one. This will correct the issue.
Aug 19, 2010 | RIM BlackBerry Pearl 8100
I put fresh batteries in my sb 600, i took a few pictures and then the flash was not as powerful and 2 red lights kept flashing on the front, why?
Ok, there are several things to consider. First of all, don't use standard alkaline batteries, the flash needs a lot of power and will drain those quickly. Use either lithium batteries (most powerful non-rechargeable) or invest in NiMH rechargeable batteries. Those would be your best choices for AA's.
Now to your flashing red lights - on the Speedlight flash they fulfill 2 functions, one is as auxiliary ready lights (if used as wireless remote flash) but the blinking in your case points to their other function - it blinks 3 times to indicate possible under exposure of your photos at maximum output level. It's basically telling you that the flash was not strong enough to properly illuminate the scene you tried to shoot. That doesn't necessarily mean the batteries are going flat, but you could simply be out of range of the maximum flash power. Your flash has a guide number of 30 - that means at a zoom head position of 35mm (if your lens is at 35mm) and your ISO is 100, then the maximum range of the flash is 30m (approx. 68ft). If your subject is further away, you would get an underexposure warning (3 blinks of the ready lights).
Hope that helps explain some things.
Jul 29, 2010 | Nikon Speedlight SB-600 TTL Flash
Will not turn on or charge. Will not power on when hit on/off switch. Will not charge (no blinking light) when plugged in.
Sorry, but this indicates very strongly that your battery is completely dead. To confirm this simply wipe the terminal of your battery very well and hold the terminals of the battery to your tongue. If battery is working, you should fill a sensation in your tongue at the instance of contact, otherwise you just got the confirmation you need that your battery is dead. I mean dead, not low, but dead. Change the battery.
Sep 13, 2009 | Kodak EasyShare M380 Digital Camera
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
New Batterys and camera indicates batterys low then shuts off.
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Dec 06, 2007 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
