Question about Sharp R-1480 Microwave Oven
Sharp R-1514 Help I'm Losing it! The LCD Display has segments not working and has progressively got worse. Can I buy this part, Can I replace this part? Appreciate any help.
  • Sharp Master
  • 9,176 Answers
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
We have full details, plus *critical* safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 05, 2008
    Novelist:
    Scholar:
  • 96 Answers
Yes, but you would have to purchase the board assy'.
If you think parts or cheap, try again.
Bob
Posted on Jan 22, 2008
6ya staff
SOURCE:
Display panel r-1514
Possible that the control pad or the main board or the processor is faulty. You can remove the top cover after disconnecting and remove the front panel, check for insects within that have nested , if so clean the board and reset the panel connection. If not you can call for help to Sharp support at your place.
Check website : Sharp
Jan 31, 2013 | Sharp R-1514 Microwave Oven
In the interactive display some of my lines do not light up any longer. Date of purchase was 7/18/2002. Model no. R-320FK. Still works great other wise, could we fix this problem without me having to buy a...
Is it the LCD display that you are speaking of? Is it full vertical or horizontal lines that are out, or only certain LCD segments of the numbers/letters?
Jun 06, 2008 | Sharp Microwave Ovens
I have sharp microwave oven model R-231F. On digital display (which is suppose to show time) only 88888 is displayed. suspect fault with the PCB behind display or keypad. Please advise how I can obtain...
First I would suggest a "hard reset". Simply unplug the oven for a minute or two, then try again.
If it still fails, it may be that the keypad has failed, or there is a bad connection due to moisture, grease, etc.
This is an Australian model, so it's hard for me to give more specific information.
But one some US models the LCD and keypad connect to the circuit board via a rubber "zebra strip" and losing that connection can result in a loss of display segments and / or key response.
I've attached a diagram showing where one can clean to restore operation in this case.
Oct 01, 2010 | Sharp R-1480 Microwave Oven
Sharp microwave 1200 watts keypad showing
Not a complete answer, but may help describe problem: Our R-510B should be the same except for color, and for several years it has intermittently messed up its display. The left side two segments on the units digit won't light up. So a digit 8, without the two vertical bars on the left, comes out as a letter E reversed left to right. Any digit that uses the two left segments (traditionally labelled segments E and F when talking about 7-segment displays) comes out wrong. Every thing else works fine. I can't tell if this is your problem.
This is almost surely a bad contact at the interface between the LCD display panel and the PC board: Typically there is a "squishy" conductive strip that connects them, and I expect grease has gotten in there. If so careful disassembly and cleaning with a mild solvent should fix it. Since we can live with it, and it usually fixes itself in a few weeks, I have not got around to taking it apart.
Bob Wilson
Oct 24, 2009 | Sharp R-510HW Microwave Oven
Display problem on Microwave/Convection Oven
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 07, 2009 | Sharp R-1502 Microwave Oven
I have a sharp microwave oven R 1514. there are 4 buttons on the front and one is broken, will not pop back out. I bought new springs and need help with the installation
It looks like you need to remove the unit from the wall, remove the outer cabinet sheet metal, then remove about 6 screws from the backside of the control panel.
You should be able to tell as you get in there what needs to be removed.
But it doesn't look like you can access to replace without taking the outer cabinet off.
Jan 24, 2009 | Sharp R-1514 Microwave Oven
LCD Display only partially working
I had the same problem with the same model. Died about 6 mths after the purchase but I couldn't return it. It looks like conductive rubber between motherboard and display goes bad and there is no replacement. I leared to 'live with it'.
Just make sure you press clear every time before entering cooking tim. (Beeper still works so I know that I pressed a button)
Jan 22, 2009 | Sharp R-1514 Microwave Oven
Sharp R1210 LCD display
Actually there are two good options for you.
First, we repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
Or you can order a modified control unit from us which has our proprietary fixes designed to repair and prevent these common display failures.
Please feel free to contact me directly if you need more help.
[email protected]
Jul 08, 2008 | Sharp R-1210 Microwave Oven
Microwave
I wiggled the ribbon cable between the control board and the intermediate circut board. The LCD came back for an instant. I am sure it is this ribbon cable. It looks like it is held on with adhesive. How can it be impossible to repair if people are offering to do it less than 40.00 dollars to fix it? Someone must be selling a replacement ribbon cable that will work.
Mar 20, 2006 | Sharp R-1501 Microwave Oven
Sharp R-1480 Microwave Oven Logo
96 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
