Question about Brother MFC 420CN All-In-One InkJet Printer
Scanner when i scan a page, 8x10 reg sheet of paper it only scan s area 4x6 i cant get it to scan the comple page..wasting lots of paper
  • 832 Answers
Plz help me to understand: waisting paper by scanning?????
There is no paper to waist!
The machine scans the whole glass! The settings for scanning can be set by the scan software. Do have a look there. It might be that the settings auto crop the size.
In case you run copy do change the paper size.
Posted on Jan 22, 2008
Can Lexmark x2470 scan and print a double sided document?
after reading the manual, http://www.lexmark.com/publications/pdfs/2007/2400/ug_en.pdf, yes it is possible - not that it tells you how to do it though so read on.
Until you become familiar with the process just use one sheet of paper at a time in the printer.
As you know, in the scanner the top right of your document goes to the right hand front corner of the scan bed (the clear window), place the page on the scanner and scan.
Pick up the printed sheet of paper and flip it so the left hand side edge is now in your right hand and the right hand edge is now in your left hand and you are now looking at the blank side of the paper.
Insert the page back into the sheetfeeder.
Flip the page to copy in the scanner so the rearmost edge of the paper is now to the front of the scan bed and the front edge of the paper is now towards the rear (you should now be looking at the page you scanned previously).
Scan the page.
you should have now scanned both sides of one sheet of paper to another sheet of paper.
as your printer does not have a sheet feeder for the scanner you have to do the process manually. hope this helps.
Apr 20, 2011 | Lexmark X2470 All-In-One InkJet Printer
How to scan photo to save on computer ?
Instructions Things You'll Need:
  • Pictures to scan
  • Computer
  • Scanner
  1. Step 1 ** Prep your photos **
    What we're going to do here is take all your photos and put them onto one 8 1/2 x 11 sheet of paper.
    So take some tape and put it on the BACK of a photo. Then put that photo on the 8 1/2 x 11. You want to do it on the back so it won't ruin your original.
    Then repeat this for the other photos you've got. And make sure you leave some space between the photos. This is so they don't get stuck together or overlap.
    If you have lots and lots of photos that won't fit on one page, then use multiple pages to hold them. In other word, put as many as you can on a page.
  2. Step 2 ** Preparing to scan**
    Now that you've got your photos on an 8 1/2 x 11 piece of paper, it's time to put it onto the scanner. And be careful when holding the paper so your photos don't all fall off.
    Now carefully lay the paper with the photos facing DOWN on the glass of your scanner. And it doesn't matter if you're using a flatbed scanner or one of those combo printer/scanner/fax machines.
    TIP #1: I suggest making sure your glass is clean and free of streaks beforehand. Otherwise, you may see lines or distortions when the photos are scanned.
    TIP #2: Do NOT feed the paper through the sheet feeder if you have one. This may jam the feeder or damange your photos. So make sure you only lay the paper on the glass!
  3. Step 3 ** Ready to scan **
    The only thing left to do now is actually scan your photos. Now depending on your scanner software, you may be able to scan a specific area.
    In other words, many scanning software programs allow you to select the region or area of the paper you want to scan. If so, then I suggest you use this to crop your image around a specific picture. This will make the process easier.
    When you've done this, scan it! Once it's on your computer, you can edit it to make it ligher, sharper, etc. Or save it as is. Then you'd repeat this process for the next picture.
    If your software won't allow you to scan a specific area, then you'll need to scan the entire page. Do it! Once the image is on your computer, then you can use editing software to copy a specific portion to a new file. This is what you'll need to do to get individual photos.
    As an alternative, you could crop the one you just scanned and then save it. Then rescan the whole page again and crop it to the next picture. Both ways work the same, so is your choice which way to go.
Hope it will help you :)
Jul 23, 2010 | HP PSC 1350 All-In-One Thermal Printer
Trying to find the answer to this problem.....Help!@! --can't print 4x6 picture on dell 3110cn
First question:
Does this printer support a paper size of 4x6?
Are you using a 8x10 sheet that you want several images placed on it?
How does the failure manifest itself? For example, do you see an error code on the printer?
Don
Jan 22, 2010 | Dell 3110cn Laser Printer
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
The calibration sheet has poor color as well black, gray, blue?
First of all, you only need to calibrate the printer once (when you first set it up).
Second, you can calibrate it on regular paper.
Third, if you can print pictures without a problem, then you should not worry about the calibration page at all.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
NO CALIBRATION SHEET
Hello, you can print a calibration sheet from the front panel of the printer. Hit menu on the panel of the printer and scroll down to calibration printer and hit ok. Then hit ok on print calibration page and it should proceed to print a calibration page. After it is done printing, it will tell you to scan the calibration sheet.
Feb 10, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Brother MFC 420CN All-In-One InkJet Printer Logo
98 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
