Convection Heater Light on Knob HBH 5015
Is this baseboard heater even made anymore. I bought it in l995. It heats beautifully, but the light on the temperature knob flickers anymore. Is this a dangerous sign that something in going out in the heater?
  • Pink Patt Jan 23, 2008
    What a wonderful answer to my problem. Clear as a bell. Thanks a million.
    Novelist:
  • 139 Answers
It is normal for small orange neon indicator lamps to blink or flicker when they're about to burn out. This should not be a problem unless you notice other electrical problems such as sparks or smoke.
Any easy test for electrical problems in your heater is to turn on an AM radio in the same room with the heater...and tune it to a clear station that you can hear clearly. If you hear steady crackling sounds or static in the radio while the heater is on, then the heater should be inspected for electrical problems.
Posted on Jan 22, 2008
Optimus LH-88 Baseboard Convection Heater - no heat
is that switch reading 0 ohms?, if it is, the triac has failed on the circuit board, if it is open then replace the switch. you can order a new circuit board from the manufacturer. of course you've checked to see that 240 volts is getting to the heater.
Mar 16, 2014 | Optimus Electric 30" Baseboard Convection...
Why doesn't heater heat up when turned on ?
  • I bought 3 convection heater ( model 052-2026 ) .Two of them stop to heat after 2 years using . The third, stop to heat last december. Canadian Tire ( store where I bougt the product ) told me to contact Garrison Company . Now , I want to get refund. Michel L?ger Quebec, Canada
Mar 04, 2014 | QMark Portable Hydronic Electric Baseboard...
This heater is a 2000 watt garrison convection wall mounted heater. the light is on but the heater does'nt heat up
The heater is disconnected or there is a damaged wire. You can try to open it up or bring it in. I would suggest bringing it in for repairs.
Elisa Jed ' http://www.encoremec.com/about
Knob broken
You might try a heating wholesaler in your area If you have the make and model # some supply houses might be able to get them or are placement got you. If not If you have the make you can sometimes contact the manufacture and they might be able to send then to you.
Nov 03, 2013 | Fahrenheat Built-In Baseboard Thermostat...
Baseboard heater running all the time
since they have indivial twist knobs that regulat temp, the thermostat is bad on one in hall either replace knob which should have thermostat built in or whole unit
May 03, 2009 | Electric TPI CORP TBS BASEBOARD HEATER...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Oil baseboard heat v electric baseboard heat.
Two 8 ft baseboards will heat this basement fine. You should eliminate any sources of flooding before you invest in refinished your basement.
Feb 14, 2009 | Fahrenheat PHH15002 Oil Filled Baseboard...
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
How do I wire up a F2544 baseboard heater with a single pole themostat
It sounds like you are not getting the correct voltage for the heating element. If you wired a single pole thermostat, and its a 220v unit, then it will not get hot enough, like you are saying. If its a 220 heater, you need a 2p2t thermostat. The parts supplier will know what this means.
Mar 17, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
107 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
