Question about Samsung HCL4715W 47" Rear Projection Television
Blue Convergence problems
I have a Samsung TV, Model #HCL4715W.  The tv was given to me and it is horizontally pinched from the top and bottom and the blue convergence will not move when I try and adjust it.  I have researched the problem and it sounds like I need to replace a part called the IC STK392-040.  If this is so please let me know if there is anything else I need to check.  I also have no clue on how to fix a tv, but I am very good at following directions and have fixed electronics before and know how things work.  If you could email me a description on how to repair it or what I should do that would be great.  Thank you
  • Samsung Master
  • 8,617 Answers
Yes thats what you need. Just go to radio shack get a de soldering Iron (the kind with the rubberbulb works fine) as wel as a fine pointed low wattage Iron. Also pick up a tube of heat sink compound while your there. Then lable your wires on the tv that you remove. Desolder both STK392-040 chips and solder in the new ones. Just ve careful not to bridge any of the pins with solder chck them with a magnifying glass. Dont forget to coat the back side of the new heat sinks with heat sink compound. You will need to adjust the convergence when youre finished. Just go slow it takes about an hour. I would also vheck the resistors right next to the ICs at times on or two of them get burnt when the ICs go out. Heres a link to where you can get the replacement ICs.
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=78719eac787d8a9ab4cdc46058425c96&keywords=STk392-040&x=2&y=8
Posted on Jan 22, 2008
6ya staff
SOURCE:
Samsung HCL4715w Hdtv convergence issue
Maybe you can fix it in the service menu.
Turn off TV, press mute then 182, Turn on TV and check out new menu items
Jan 24, 2013 | Samsung HCL4715W 47" Rear Projection...
Our samsung HCl4715W tv is all connected right but our picture is scrambled where you see double exposure and the color is off. Can not find our manual. any suggestions?
The problem of your tv is the convergence. Projection tv set has a 3 colors red,blue and green this 3 colors must be properly lined up to look the video normal. When this 3 colors is not properly aligned the video will produce a double image of color or like a 3d or wavy. In order to fix this problem you should adjust it in the menu program of your tv you should move any of the colors to up or down, left or right if you cannot align the 3 colors the problem is the convergence ic it must be replace. To locate the convergence ic you should remove the back cover of your tv but be sure to unplug your tv, you will see this ic attached in a large aluminum plate it has a marking of stk--- and followed by a numbers. or you could contact a service technician do do it for you and save you from stress. Good day and best regards.
Jul 17, 2011 | Samsung HCL4715W 47" Rear Projection...
Samsung HDTV model HCL4715w1 has horizontal wavy lines in the middle of the screen. Is it worth Fixing? Any solutions to this problem?
Yes,tv screen have R,G,B colors lines mis alingnments,have colors shaded pictures or 3D pictures look aike?Tv have a problems known as convergence pictures problems.The tv convergence board it is dead.This convergence board must require replacement of 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence pictures problems.U have some mechanical skills like take things aparts and putting it back together again?Yes,try website like Tvrepairworld.com to buy a whole refurbish tv convergence board for the replacement.The DLP tvs brands names Samsung and Akai used the same tv convergence board.Or tries those tvs shops will cost u like $300-$350 for parts and labors.
Jun 28, 2011 | Samsung HCL4715W 47" Rear Projection...
Blue image is ghosting and not lining up with other colors. Perfect focus is on but with "no sensor data" message at top
The tv have a problems known as a convergene problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergnce board,must be replaced to solved the tv picture convergence problems.Can u do basic things like take things aparts and install another things into it placed?Yes?Try website like Tvrepairworld.com to buy a whole refurbish convergence board for the replacement.The DLP tvs Samsung/Akai tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 14, 2011 | Samsung HCL4715W 47" Rear Projection...
Tv will not turn on
If your convergence ICs are bad set will not come on 1 of the ICs controls Off/on STKs big black ics replace both STK392-020s use 040s For Parts call 1-800-223-3205. www.electronix.com
Jan 03, 2009 | Samsung HCL4715W 47" Rear Projection...
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Yes taht is exactly waht you need. You will need two of them plus some heat sink compound. It is a straight forward repair. Just unsolder the old ones and solder in the new ones then adjust your convergence when your done. I am enclosinga link where you can order the parts online for 10.99 each. Hers the link
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=76a2ed194c7108f45abccc4442d79fd0&keywords=STK392-040&x=10&y=8
Jan 22, 2008 | Televison & Video
Convergence
you have a samsung? hcl4715... your convergence chips have most likely blown...sorry..
Dec 08, 2007 | Samsung HCL4715W 47" Rear Projection...
Convergence
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
