Blue Convergence problems
The tv was given to me and it is horizontally pinched from the top and bottom and the blue convergence will not move when I try and adjust it.  I have researched the problem and it sounds like I need to replace a part called the IC STK392-040.  If this is so please let me know if there is anything else I need to check.  I also have no clue on how to fix a tv, but I am very good at following directions and have fixed electronics before and know how things work.  If you could email me a description on how to repair it or what I should do that would be great.  Thank you
  • Max Tidland Jan 22, 2008
    thank you your a life saver
  • 8,617 Answers
Yes taht is exactly waht you need. You will need two of them plus some heat sink compound. It is a straight forward repair. Just unsolder the old ones and solder in the new ones then adjust your convergence when your done. I am enclosinga link where you can order the parts online for 10.99 each. Hers the link
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=76a2ed194c7108f45abccc4442d79fd0&keywords=STK392-040&x=10&y=8
Posted on Jan 22, 2008
Im having a convergence problem with my 50HX70. The tv was working fine until one day i turned it on and there was a blue shadow on the bottom half of the screen. I tried to adjust it and the horizontal...
Tv have a dead convergence board.The convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to fixed the tv picture convergence problems.U have all tools and can do soldering?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it urself.Or the shop,will $300-350 for parts and labors.
Mar 18, 2011 | Toshiba 50HX70 50" Rear Projection...
Convergence lines are SLANTED. Red line is above
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Apr 26, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Pioneer SD-641HD5 red convergence - not chip problem!
Replace Both of your STKs if they are STK392-110s do not go back with them use STK392-180s better ICs, The 110s fall apart and do not hold up.
Nov 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
CRT Rear-Projection Red Vertical Alignment
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Oct 11, 2008 | Philips 51PP9200D Television
Red Convergence
http://schematicscom.blogspot.com/
http://homenol.blogspot.com/
Visit these sites. Convergence procedure of projection televisions are given in detail.
Mar 28, 2017 | Televison & Video
Blue Convergence
Hello All Above,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Mar 11, 2008 | Samsung HCN653W 65" Rear Projection...
Yes thats what you need. Just go to radio shack get a de soldering Iron (the kind with the rubberbulb works fine) as wel as a fine pointed low wattage Iron. Also pick up a tube of heat sink compound while your there. Then lable your wires on the tv that you remove. Desolder both STK392-040 chips and solder in the new ones. Just ve careful not to bridge any of the pins with solder chck them with a magnifying glass. Dont forget to coat the back side of the new heat sinks with heat sink compound. You will need to adjust the convergence when youre finished. Just go slow it takes about an hour. I would also vheck the resistors right next to the ICs at times on or two of them get burnt when the ICs go out. Heres a link to where you can get the replacement ICs.
http://www.electronix.com/catalog/advanced_search_result.php?ELECTRONIX_CATALOG_SESSID=78719eac787d8a9ab4cdc46058425c96&keywords=STk392-040&x=2&y=8
Jan 22, 2008 | Samsung HCL4715W 47" Rear Projection...
Blue out of whack around sides
I have the convergence problem with the red. After reading your site I replaced the 2 ICs and the problem is worse. Before the only problem was I could not adjust the red horizontal. Now I have no control over the vertical or horizontal and the overall picture is very red and it bows at the top and bottom very bad. A friend said I might have the ribbon connector in wrong or the convergence (silver box?) box maybe bad. Any ideas? Thanks,Dave.
Oct 12, 2007 | Philips 55PP9352 55" Projection Television
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
