Question about Maytag Neptune FAV6800AW Top Load Washer
Neptune FAV6800aww Will not go into spin
My Neptune top loader keeps trying to go into spin cycle but the load is always out of balance. I have tried several different load sizes and it does not seem to make a difference.Once it tries to go into spin the tub is so out of balance it stops and tries to reposition the load. This continues until it finally faults out for dc. The washer is level. I have ran all of the diagnostics and everything is working like it should with an empty tub. I could really use some help on this one.
  • 3 more comments
  • bamabest Jan 27, 2008
    I have the exact same problem. Please someone help.
  • Honeydoman Feb 09, 2008
    This is Honeydoman with a follow up. I am fairly mechanical inclined so I decided to take the clutch assembly apart. Since this is what everyone was saying the problem was. I spent 5 hours on the internet to find the answer.
    What I found after removing the clutch and disassembling it was a broken coil spring. The spring had broken right at the tip that slides into the housing of the clutch. I am not certain but I believe this may be where the clutch fails on this model. I took the spring out and dug out the broken tip. Once I had them out I took a blow torch and heated the tip of the spring and shaped it back into the same shape of the piece I dug out of the clutch housing . Then I installed the spring back into the clutch housing and reassembled the clutch. So far this has fixed the problem and all is well again. I want to caution anyone who is going to try and tackle this. This is not a job for anyone who is not familiar with working on machinary and is not mechanically inclined. The entire tub and motor assembly must come out of the washer. Once you have it out and turned upside down removing the clutch is a breeze. www.easyapplianceparts.com has exploded views of the washer that helped me out.
    The other route is pay out the @!& for the part and have a qualified service technician install it. The part will run between $130.00 and $190.00 just depends on who has it in stock.
  • Anonymous Feb 16, 2008
    UC error code at spin cycle
  • Anonymous Mar 04, 2008
    Honeydoman,
    I'm having this same problem with my machine. I'm curious as to your solution - how did the clutch affect the unbalance issue?
    Soupman
  • Anonymous Mar 08, 2008
    Yup. me to I am having the same exact problem .
  • 335 Answers
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors in the spin cycle, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium and heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Posted on Dec 15, 2008
These machines are absolute junk. Mine throws the EC code constantly on any load less than absolutely full. It also eats buttons off of everything constantly. So much for the "dependability people." Their ads are a joke and so are the machines. I used to have a very simple Sears Kenmore machine and it never gave me an ounce of trouble. Never again Maytag, costly piece of junk.
Posted on Mar 21, 2008
Posted on Feb 09, 2008
  • 3 Answers
I have the same problem right now. It doesn't matter if it's a small load or big one. We built a special platform for it so I know it's completely level.
Posted on Jan 30, 2008
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl top loader is stuck on 23 minutes and just keeps going back and forth. There are no error messages. and water is sitting in it. Any ideas?
don't visit this site very often and I don't want to troubleshoot FAV6800A or FAV9800A issues here.
I have two DIY sites that I try to provide owners support as a knowledgeable owner.
You problem is related to a Clutch Issue. Google these keywords ""[FIXED] Maytag neptune FAV6800aww wont spin""
It's a long post it was difficult for me to pull accurate info from the owner for the issue. Fo him the Upper One-Way bearing on his machine was seized. All of these machines are ready after 6 years + of operation are ready for a Outer Tub rebuild. It's a few hundred dollars to do if you have to replace the Clutch Pulley as part of the process.
But one step at a time read the thread [FIXED] Maytag neptune FAV6800aww wont spin and see if this is a DIY project for you. It
Jul 02, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My MAytag will not spin the water outta my clothes on spin cycle
If you machine is a FAV6800A or FAV9800A don't worry about the last two letters of the model number.
Google this; Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum and you can get the Service Manual and repair support at that site..
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help.
Feb 28, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Why is my Maytag Neptune top loader continually reading "dc" and is not completing wash cycle?
You can't get the FAV6800A/FAV9800A Service Manual from this site.
Google this ""Sticky: Neptune TL Washer FAV6800AWW""" Post your problem at this Forum. You will find the FAVA9800A/FAV6800A Service Manual at that site.
Jan 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune top load washer model # fav6800aww will not drain and spin if anything is in it, remove all articles and it will drain and spin
Are yiy failing in Spin Cycle wuth dC or uC error codes?
If so see if this post Clutch Fix. There is a link to the SM.....D*ick
Sep 18, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune top loader model fav6800aww has an error code od
See if this post http://www.fixya.com/support/t4757262-i_have_a_letter_showing_and_it_say_o_d_w will get you started.
You have lost signaling from the Left Hand Lid Lock. If you want to DIY I will try to help........Rich
May 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" error code Maytag Neptune FAV6800Aww
At 12 years of age, your Maytag may be telling you it needs to be replaced.
Sep 23, 2017 | Maytag Neptune FAV9800AW Top Load Washer
FAV6800AWW MAYTAG NEPTUNE
If you are sure that the load sensor is not the problem then you really need to get a service person to try to correct. The side rotators should not be moving.
Jun 06, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
409 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
