Refrigerator not cooling...makes sound like it working really hard, high pigtched hum forabout 5-10 seconds then click and occasionally a hissing noise. neither refrigerator nor freezer cooling AT ALL. did this about 2 weeks ago, for about 1 week then started working again perfectley without any intervention. this fridge/freezer is only about 3 years old and was brand-new. otherwise have had NO problems.
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
The noise is water dropping on the hot defrost coil...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
