Question about Haier HLP21E Top Load Washer
Water won't fill the machine
I followed the instructions to the letter, but the water won't
flow into the machine. (portable electronic washer)
it looks as though there is a flow restictor just past the airator screen at the machine end of the water hose.
dose that washer need to be removed?
thet piece is not mentioned in the instructions.
  • 118 Answers
Do not remove that piece. It is needed.
Posted on Jul 22, 2009
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
Washing machine won't fill
This can be due to a clogging of the inlet valve as the water flow is restricted. You can remove the water line to the washer and check the flow , then check if the inlet valve works after the power is switched on the washer , If there is no flow to the drum then the inlet valve is faulty provided there is power to the valve or the main controller is faulty
Jun 26, 2012 | GE Washing Machines
The water won't stop filling up the tub causing it to over flow.
it could be the pressure chamber is blocked up with old hard soap or the pressure switch is jamed
May 28, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Water won't stop filling
If the water still flows in when the machine is off the inlet solenoid is faulty, if when you push start it fills and keeps filling then the problem will be with either the electronics or the pressure switch.
You really need to get someone who has experience with whirlpool machines to look at it for you.
Mar 08, 2012 | Whirlpool Washing Machines
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
What does it mean when the washing machine stops and blinks the letters fh?
The fault code "FH" means basicly a water inlet flow problem. Make sure you check that you have enough pressure and the machine is filling to the correct level
Have the water flow meter checked or replaced. If the internal wheel sticks inside the meter, the CCU will think no water is entering the washer and give you this error code.
Do you notice an above normal amount of water in the washer when you notice the error code? This is a good indication the flow meter is faulty. You can obtain the part from Sears and install it yourself. Very easy fix
Sep 11, 2009 | Kenmore Washing Machines
F H beeping
ck fill hoses at rear connection and inside fill valve for debris..also be sure both faucets are fully on and there is sufficent water flow through both to washer be sure drain hose end is 30-36 inches from floor and fits loosely in standpipe ..allck ok then replace flow meter ..remove top on left side small round object with hose in each end 1 end goes to dill valve other to dispenser..flowmeter ckd for water flow into washer
Nov 01, 2008 | Whirlpool GHW9100L Front Load Washer
Washer filling with water after cycle
My oppinion, if it is filling with water after the cycle, replace the valve. The screens are to prevent sediment in the water from getting into the valves. If you try to remove the screens, you will likely dammage them and allow more sediment in. Enough sediment will allow the valve to stay open far enough to over flow the machine.
Jun 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Haier HLP21E Top Load Washer Logo
114 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
