Question about GE JASRM24912 Remote Control
Television My television first har red and blue lines, now it has many white horizontal lines and squiggly white lines.Also sometimes I get a reflection of what is on the screen. Sometimes when I hit the TV it goes back to normal but often after 10 minutes or so the lines reappear.
  • 934 Answers
You have poor solder joints, (called ring cracks), somewhere on the foil side of the board... The slap and tickle method you use brings them back together temporarily then heat expands them and they separate again... Nedd to pull the board, find them, and solder them up..
Bill
Posted on Apr 09, 2008
The tv has red images, I cannot get the red convergence line vertically to straighten, it is squiggly, the horizontal is straight, and the blue and green lines are both okay
the 43h71 has a pair of convergence ics that commonly go bad and cause this problem. replace original stk392-110 with stk392-120. the upgrades have a collector rated at 4 amps vs the 110's 3 amps and should be more reliable.
also know that they hyperboard in this set can cause squiggly lines throughout but will not affect the convergence.
Jul 06, 2010 | Toshiba 43H71 43" Rear Projection...
Sony Projetion TV has horizontal blue lines across the screen
It is hard to tell from your description what is wrong--confirm actual model number for me.
I am going to attach some photos of what CONVERGENCE troubles look like--they may or may not look EXACTLY like your set but if you have something similar I can help you with more information.
If this helps you rate this solution as I do this here for free.
SD TECH
Dec 26, 2009 | Sony KP-51HW40 51" Rear Projection...
My RCA big screen picture messed up after one of my children fell nto screen?? How can I fix this
The picture on my 52 inch RCA Projection television has green, red and blue squiggly lines around the objects on the screen and the picture looks 3-D.
Oct 30, 2009 | RCA P52960 52" Rear Projection Television
Red/Orange horizontal lines
it could be that the tv convergence circuit is going bad. One shure way of finding out is to go to the tv feature menu(picture,audio etc.) and select the customer convergence setting, you should get a cross hair pattern(cross in middle of screen). that cross should be white and by aligning the red or blue colors they should move left, right, up or down
Jul 27, 2009 | Akai PT5492S 54" Rear Projection...
52 Inch Zenith TV has red blue and green squiggly lines what is wrong, no picture
I belive that the red light means that it is off and the blue means that its on
Jun 10, 2009 | Zenith D52WLCD 52" Rear Projection...
Blue Ghost
you will need to replace 2 stk ic [ parts ] after that the technician will have to realign the picture, sometime also some resistors get bad along with one or 2 fuses
Dec 15, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue shadow and lines
This would apear to be a convergence issue ..sometimes you can go into settings and converge it manualy.. if this is to far out of range. a service tech will have to adjust inservice mode. if the convergence cuircits are not failing. if so then there are cuircits that will have to be replaced. is this just a blue shadow?.. is there green or red shadows. if not it may not be a major repair.
Dec 18, 2007 | Samsung HCN653W 65" Rear Projection...
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
GE JASRM24912 Remote Control Logo
156 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
