Question about HP Pavillion DV6227 Notebook
Does not boot up
When I turn on the laptop
1. fan on 4. hard drive on
2. leds on 5. screen is inop
3. cdrom on 6. keyboard is inop
and the laptop shuts off after 2 minutes and restarts again.
Help please. jaz
    Genius:
  • 1,067 Answers
Ovewr heating greese on cpu no good power c hips getting to hot dusty inside clean it out get labtop cooler pad
Posted on Jan 22, 2008
How to reformat r430 samsung
Steps to reformat:
1. If you do not already have the Operating System (OS) software, download and burn it to a cd or make a flash drive bootable.
2. Put in the disk or plug in the flash drive and Turn off the computer.
3. Turn on the computer, and as soon as you see the samsung logo, Press Delete (around 3-5 times). And you should get to the BIOS screen.
4. In the bios, look for startup/boot options and set the first boot device to CDROM or if booting from a flash drive choose Removable Disk.
5. Save and quit the bios and the computer will reboot.
6. Once the computer passes the Power On Self Test (POST), it will automatically check for the first boot device (CD or Removable). If found, it will prompt you to boot from the boot disk. Press any key or Y for yes.
7. Follow the prompts from there.
NOTE: It is usually best practice to do a clean install removing any prior data from the hard drive.
Mar 03, 2014 | Computers & Internet
What do i do it says this on mine this is what mine has 1. IDE0 2. IDE1 3. USB FDD 4. USB HDD 5. Network Boot : Atheros Boot Agent 6. USB CDROM
Options 1 and 2 are internal hard drives. Option 3 is a USB flash drive, option 4 is a USB hard drive. Option 5 is a network boot protocol to boot from a local server. Option 6 is to boot from a USB CD drive.
If your computer does not boot in the current configuration, try selecting IDE1 instead of IDE0. One of those two drives has your operating system on it. If neither will boot, then you will need to install an operating system on one of them by inserting an install disc in a USB CD drive and selecting option 6.
Oct 25, 2012 | Acer Aspire One D250 (99802378332) Netbook
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I forget my password in u3 what can i do??????
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I forget the hdd password
Jan 15, 2011 | Computers & Internet
How i can boot from a cd to install os
1. Turn on your computer
2. press the proper key in order to enter bios setup while black screen in progress. this key may f2 or f8
3. investigate the boot device order
4. set the cdrom as #1
5. press f10 key to save and exit.
6. put a bootable installation CD/DVD into the cd/DVD reader's tray.
7. cut off the po-wer
9. power on the computer
if everything ok, the computer will check the cdrom device to boot and start booting from cd.
Aug 18, 2010 | Toshiba Satellite 2060CDS Notebook
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Laptop power shuts down after 2 seconds
hold F2 key and set up to default settings choose to boot to the hard drive save it and exit.
if that does not work then hold F8 chose to log in safe mode and from there try to find what issue is causing that particular problem...
otherwise try to download the ultimate boot cd (click here) and burn it into a bootable cd inserted on your pc and repair whatever is causing your nightmare.
Please leave feedback
Jan 09, 2009 | Computers & Internet
Open Questions:
How to Save Data Backups for 100 Years - Data Backup and Online STORAGE Get all you important data saved safely and securely on the highly advanced online cloud backup solution of Dataalign. This facility of providing large space for online cloud backup is different from its counterparts as it makes optimal use of advanced technology to device features that helps the user to make maximum use of the available space by setting the number of versions and days you wish to keep a file after which it is automatically deleted. Also, the feature of version history helps in viewing the history of each stored file and thus, also let's undo decision mistakes if made in the past. The server cloud backup solution of Dataalign is an amazing way of backing up all your files, folders and data whether related to your business or personal. Many more amazing features of Dataalign makes it super secure and easy to use by anyone. There are different categories of backup plans in Dataalign for various uses. You can choose the plan according to your needs from home free backup, personal standard backup, social backup, personal pro backup, family all in backup and home pro all in backup. The Unified cloud backup feature of Dataalign cloud backup helps in securing data located on various platforms and in different devices at a single place. Everything on your computers, tablets, and smartphones, external drives, servers, network devices and even cloud services like dropbox automatically get imported and saved on Dataalign. The cheap online data backup of Dataalign provides easy access and retrieval of data from any place using any device. Free cloud data backup of Dataalign helps in protecting all your data like documents, photos, music, videos, contacts, messages, calendar, call logs etc. In case of situations when your device gets damaged or you want to upgrade your device, you won't have to worry about transfer of data. You can import all your data by simply installing the Dataalign cloud backup app. With Dataalign keeping all your data safe, you can search and discover documents, presentations and spreadsheets from any device. You can even discover OCR content from scanned PDFs and images. For more information and cheap online cloud backup contact Dataalign at toll-free helpline number +844387-9959.
Sep 21, 2018 | Super Computers & Internet
See all HP Pavillion DV6227 Notebook Questions
HP Pavillion DV6227 Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
