FixYa.com
Tags:
Nikon N5005 35mm SLR Camera
Help!!!!
posted by maxson on Jan 22, 2008
when I hit the button to shoot all it will do is focus. It won't take the picture. The green light comes on. The flash also dosen't work. could the flash bulb be burned out thus preventing the shot? It is asking for flash.
Comment by maxson, posted on Jan 22, 2008
It doesn't appear to be. although they don't open. I am at school so when I get home I will take a closer look and responed again thank-you for your time and help maxson
Comment by maxson, posted on Jan 24, 2008
where are the shutter blades? I have film in will it hurt it?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by cammedic, posted on Jan 24, 2008
It would be best to rewind the film to have a look at the shutter blades from the back with the door open
by cammedic, posted on Jan 22, 2008
You might want to have a look a the shutter blades, Are they out of place by chance?
Solution #1
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Thanks for the input will try it and let you know. Maxson
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
eltroman
Rank:Wiz Wiz
Rating: 83%, 108 votes
Remove the lens from camera.
Look inside pass the mirror, how is the shutter?
Should be flat with the film with no warp or opened shutters.
Or try this:
Lens out, set camera to M (manual mode).
Shutter set at 1 (One Second).
No flash.
800 ISO
Lnes drive pin (recessed) fully into the body, not S or C.
Fresh batteries.
Set self timer on.
Press shutter button.
Camera should blink and then shutter should be tripped.
This will also check to see if you have enough power for min. of one shot.
atdlee@netzero.com
Can you Help with these Film Cameras problems?
Film Cameras
samsung maxima zoom 80gl
2 new batterys put in hearing... Answer This...
Film Cameras
fuji discovery 2000 zoom
i just need some general... Answer This...
Film Cameras
fix my camera
I have a Fuji s5700, I used it... Answer This...
Film Cameras
manual please
We have a older canon... Answer This...
Repair Service
Find Film Camera Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
