Help me?? what kinda cconnections do i need to connect my printer to my computer?
USB is the most common household printer to computer connection, just plug the printer in and it will walk you through the windows set-up, or put the CD from your printer in your computer and the CD set-up will walk you through the set-up, when you buy a printer ask a sales person to show you how to connect it and set it up.
Posted on Jan 22, 2008
The usb does not work
if you have the user guide there is a section that explanes how to connect the usb hub to your computer or use the link : http://support.gateway.com/s/Manuals/Monitors/8511446.pdf to download it.
Page 10: you will need a compatable usb cable and the power adaptor to make the cconnections, they should have came with the unit when new.
sprint6@zoominternet.net
Dec 09, 2011 | Gateway FPD1975W 19" LCD Monitor
When I use the music player I only get sound in one ear of the headphones
Use another headphone to confirm if the wire is cut or the jack connection within is faulty.
Most of the time these cords are so delicate that a slight pull can stretch and cut cconnection off .
Once the test proves right you can either get a jack fixed or might need to buy a new one.
Sep 17, 2010 | Nokia 5800 XpressMusic Smartphone
What do I do if my screen goes completly white?? Like I can't view anything??
Possible fault in the main board that is not controlling the backlight. Open to ccheck for display cconnections or connectors to the main board. the ribbon connections can also be a possibility.
If the door is closed many tiimes does it return back to normal, if so the ribbon connection can be cut.
Sep 14, 2010 | Motorola Mobility RAZR V3
My dryer cconnection is to high for my dryer cord to connect
There is a cpl things that you can do. The best way is to go and buy about 3ft of wire, a plug that fits the outlet, and a receptical that will fit the dryer plug. And make a short 220v extension cord. Or you can get enough wire to replace the other one and a new plug end. Place the plug end on one end of the wire and you will have to get terminal ends like the ones on the cord now. And clamp them on the other end of the wire and install it on the dryer. Make sure that the center wire goes in the center. And the other two dont matter. However if the center wire is at the top on the outlet? Then the black wire goes on right.
May 21, 2010 | Dryers
P1005 hp printer windows vista will not recognise
hmmmm i would first make sure all window vista driver are in first. then try installing the cd. or if you want to try the driver only and not all the extra software...
1st uninstall the driver and software and do not connect the printer. until it asks you.
2nd put the factory cd for the printer but do not let it run automatically. cancel the installation.
3 you go to the control panel add printer, etc. have look for the driver and say "have cd" or go to the cd drive where the vista folder is holding the driver file.
i know this can be tidious but its kinda old school for installing a driver instead of letting the cd do it automatically have the computer find the driver on the cd first. dont add all the extra software. try it and see if it works then try to add all the extra software.
personaly i think sometimes the vista updates stuff where it screws with the drivers and then your computer does not know what its looking for. i hope this kinda helps. sorry for your mishap.
have you also tried connecting to all the usb slots?
Apr 21, 2010 | HP LASERJET P1005 Printer
My computer says that my printer is offline and won't print but it is on and has a wireless signal.
Most times if it says offline is because of some kinda settings issue. When my printer tells me it is offline is because IP address changed that was set up in computer to connect to printer. Make sure IP in printer is same as IP in printer settings on the computer. If not just remove the printer and readd it with new IP address. Good luck.
Jan 11, 2010 | Epson WorkForce 600 All-In-One InkJet...
What I think is the heater hose cconnection to
PUMP MUST BE REPLACED if ANY Part of it is BROKE, as this can Lead to MORE cracks, and Ending in Catistrofic Failure.
Aug 01, 2009 | 1999 Plymouth Voyager
Error code 50C, "printer cartridge error" in display
LEXMARKS ARE KINDA "FINICKY" WHEN IT COMES TO CABLES AND DRIVERS, TRY CONNECTING IT TO ANOTHER PORT ON THE BACK OF YOUR COMPUTER AND ALSO REPLACING THE DRIVERS WITH BRAND NEW ONES MAY HELP, LEX MARK SHOULD HAVE A SET UP UTILITY FROM THERE WEB SITES SUPPORT PAGE WHEN YOU BROWSE IT WRITE DOWN YOUR SERIAL NUMBER FROM UNDERSIDE OF THE PRINTER AND USE THAT WHEN YOU BROWSE THERE SITE. YOUR PINS ON THE CONNECTOR MAY BE "FRAGGED" SO DEFINATELY BEFORE YOU RE-CONNECT AT ANOTHER PORT GET ANOTHER USB CABLE THEY ARE PRETTY CHEAP AND READELY AVAILABLE AT BEST BUY AND SO FORTH, HOPE THIS HELPS JON T...
Dec 07, 2008 | Lexmark Inkjet Z517 Photo Printer
Printer connection to dell computer
the usb port on the front is for camera down loads. There is a printer port on the back by the power cord ( kinda square looking) the other end of the printer cable is the typical usb connection. This goes to the computer
May 18, 2008 | Lexmark P315 InkJet Photo Printer
53 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
