Mitsubishi WD 57833 DLP
When I pressed the Power switch (TV remote control), the green status light, marked Timer, on the front panel began blinking, as it does normally. However, it continued to blink without ever powering on. The set does not respond to either remote nor manual commands. The Users Manual says to press the Reset switch, after which the green light will blink for about a minute and except for losing any most recent settings change(s), the tv will again operate normally. No. It does not. The only way I can stop the blinking is by removing the power cord from the electrical outlet. Of course, Mitsu's help is only available during daytime business hours, not in the evening when I and most other people use their television sets. Can anybody help? I need someone, too, to help with the setup of a new Sony AV receiver. Nothing seems to work as easily nor straightforwardly as the manuals describe. My zip code is 78660. Thank you.
Ed
You problem is terminal. Look on line and read more about the blinking green light of death. Push for resolution and don't take No for an answer. Mitsu. knows there are problems.
Posted on Feb 26, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
All I get is a blue welcome screen on my Mitsu WD-65C9 DLP TV. After several seconds of blue screen, it always just shuts down. I downloaded the Mitsubishi software upgrade, but it did NOT solve...
Hi Mike,
May I know if the LED light at the front panel has a pattern of flashes or flashing continuously in green color.
Please check if you can access the "Self diagnostic screen" by following the steps below.
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code, it will help to diagnose where the fault came from.
Note : the TV must be in shutdown not switched off, or AC power cord is removed because the code will reset to "12" means no error. Use the front panel buttons not on the remote control. If you can't access the self diagnostic, press and hold the "Activity" button on the front panel for 5 secs before entering the "self diagnostic" code.
Kind Regards,
Mjsazon
Nov 25, 2011 | Mitsubishi WD-65C9 65" DLP HDTV
When I turn on the tv all i get is the welcome screen, and it will not go any futher,there is green light flashing in front of the tv. and it will not turn off with the remote, i have to unplug it.
Hi Andre,
- To activate, press the front panel "Activity" and "Channel down" buttons at the same time and hold for 5 secs. The Status led will then flash a two digit code. Example, if the error code is "23" the led light flashes 2 times(blink, blink) pause and then flash 3 times(blink, blink, blink). Let me know the error code to narrow down, it will help to diagnose where the fault came from.
Regards,
Jdvillanueva
Nov 24, 2011 | Mitsubishi WD-60737 TV
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
Mitsubishi WD-62627 62" DLP TV
Try this:
1) turn on the TV
2) from the remote control press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING
4) when done press the front reset button.
5) should be good to go!
Oct 26, 2009 | Mitsubishi WD-62525 62" Rear Projection...
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
Sep 02, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Televison & Video Logo
351 people viewed this question
Top Televison & Video Experts
