Question about Gateway 510H Pentium 2.4 GHz, 256MB RAM, 40 GB HD, DVD/CD-RW, Mini Tower Computer (510HRB) PC Desktop
D-drive my d-drive has disappeared from my computer! It won't eject a disk. it won't open to accept a disk. The "my computer" section of the start menu claims that I HAVE no d-drive, despite the fact that I have been using it for the past three years
  • criolle Jan 22, 2008
    I'm on windows XP, thanks for trying
    Genius:
  • 1,067 Answers
Are u on vista ? thenlower upper filters is what u need to del in regisrty
Posted on Jan 22, 2008
  • nick helpap
    nick helpap Jan 22, 2008
    also cheak cables maby bad ide cable or came loose
  • nick helpap
    nick helpap Jan 23, 2008
    did u change ide cable on cd rom ?
Is it possible my toshiba laptop doesnt have a dvd disk tray??
From the start menu, find "my computer" or just "computer" and open it. If you have a DVD drive, it will be listed.
Mar 05, 2015 | Toshiba Computers & Internet
How to open optical disk drive on toshiba c55 laptop
Anonymous - If you haven't already, Go to Start menu and type Computer and select. This window should show your optical disk drive. Right click on it and select Eject from the menu. Hope this helps.
Sep 28, 2014 | Toshiba Satellite 15.6 C55-A5246 Notebook...
Cannot find eject button on laptop
I assume you want to eject a Disk? Usually there is a button on the DVD?CD Rom drive door. You can open the the Rom drive by opening the Computer folder in Start Menu, right click on the device Icon, choose EJECT and click.
Apr 20, 2013 | Fujitsu Siemens Computers & Internet
My disk top door won,t open up to allow me to install a disic
Open Computer in start menu, right click on the Drive, scroll down to Eject, click. Pull the outer frontcover door down so you can access the drive, push the button on the drive , does it work? Remove the faceplate/frontcover of the desktop something is misaligned or obstructing the button on the drive or it's broken.
Jan 08, 2013 | Dell OptiPlex 380 PC Desktop
I can't open my disc drive on my Acer Aspire 5820T without using a pin. How do I get the eject button to work?
I suggest that you can use the other method to eject: press start and go to my computer, select the disk drive and you should see an eject option in the menu bar.Remember that disk drives are subject to computer admin and do not respond quickly to a button press, especially if a disk process in taking place...
Mar 03, 2012 | Acer Aspire TimelineX 5820T-5951 Notebook
Disc Drive
If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Feb 13, 2012 | HP Computers & Internet
How do I open the door to my CD/DVD player on my eMachine Tower. I use to know how but as an old lady I need help remebering now. please help
There should be a button just below the cd tray on the front of the tower. If I remember correctly, on E-Machines there is a black bar just below the tray, and the button is a small section of this bar. If you press along the bar you should find a place that presses in. That will be the button to eject the tray.
Another way to do this is to click on "My Computer", there should either be a link on your desktop, or in the start menu. In this window you should see your disk drive, usually "D:\". Right click on this icon, and there should be a menu option called "Eject", which will open the drive for you.
Thanks,
John Vickers
Aug 12, 2011 | E-Machines eMachines Desktop PC
Hi, I've just bought a Sumvision Cyclone Primus 2TB and after connecting it to my laptop it installs the drivers. Once this is complete a Microsoft Windows pop-up comes up saying "you need to format...
Try putting the unit back on your laptop and using the windows disk management utility. The directions are below. Windows Vista is a bit differenct than either windows 7 or XP.
Right click on you "Computer" Icon in your start menu
A menu will open
Chose "Manage"
The Computer Management window will open
The Computer Management window is broken down into 3 sections.
The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu.
The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have not disk will not show as active drives on the top section, but can be seen in the lower section.
The lower section will show the drive description, drive size and drive condition (online or off line) in small box on the left side of that section. Disk drives will designate a "Drive" and a number. Drive 0 is usually your internal hard drive. Then it would list drive 1, drive 2, etc, depending on how many internal and external drive sources you have connected to your computer. Then it will list your CD drives and generally show their drive letter assignments.
Next to the smaller section described above, is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show "healthy")
This is the area you can right click and get a menu that will allow you to open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition. (A note of caution here. Changing the driver letter on your main hard drive partition will cause windows to stop functioning. The main hard drive, or hard drive partition, is normally given the letter "C".) A hard drive may show two or more partitions with separate drive letters designated for each partition.
A drive that is having a problem may show that it needs to be formatted (status as Unformatted). This can be done from this window. An external drive, whether it is a hard drive or CD/DVD drive, can have the letter designator change done if you want to organize your external drives. There are times when a drive will not show up because the drive letter that they are programmed to use are taken. Most USB drives are programmed to us the letters "F" or "G". In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows.
See if this helps you manage the external disk and get it formatted so you can use it on your laptop.
If you found this answer helpful, please remember to leave positive feedback.
Thank You,
Brian
Mar 02, 2011 | Office Equipment & Supplies
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
My san disk 2gb pen is canot open but light is blinking &showing remuvabal disk on my computer
USB Pen or stick drives usually use the letters "F" or "G" drives on your computer. If these drive letters are being used, the USB drive will not be available. Also, if this is the first time you are using the USB drive, it is possible the drive is not formatted. Although this is unlikely.
I will outline instructions below to use the Disk Management tool in windows to see if the drive shows all the drives connected to your computer. If your computer is recognizing the drive as you describe. I am confident USB Pen drive will show up in disk management. You may be able to assign a drive letter and make the drive visible in you my computer window.
The directions for using disk management are listed below. A note of caution, do not make any changes on you Disk 0. or "C" drive, as this is you main hard drive that starts your computer.
Right click on you “My Computer” Icon
A menu will open
Chose “Manage”
The Computer Management window is broken down into 3 sections. The first section on the left side of the window shows a menu. Disk Management is on the lower portion of the menu. The right side is separated into two sections, top and bottom. The top portion shows a list of active drives on the computer. The lower portion shows all drives connected to the computer. CD or DVD drives that have no disk will not show as active drives on the top section, but can be seen in the lower section.
The lower shows each drive, their drive letter and status. The left section will have small boxes showing drive numbers. Drive 0 is usually your main hard drive. To the right of the smaller section is a larger section which shows the driver letter, size of the driver and condition (if working correctly will show “healthy”) This is the area you can right click and get a menu that will allow you to: open, explore, mark the partition as active, change the driver letter, format the drive or delete a partition.
In this area, you can assign the USB drive any drive letter that is not being used and this will make it visible in windows. A drive this is having a problem may show that it needs to be formatted. This can be done from this window as described above.
Please follow these directions and see if you can make your drive visible. If you have any questions about the instructions or need further assistance, feel free to reply to this message and I will assist you further.
Brian
Jan 29, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Gateway 510H Pentium 2.4 GHz, 256MB RAM, 40 GB HD, DVD/CD-RW, Mini Tower Computer (510HRB) PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
