Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Hp computer window could not start because the following file is missingor currupt: windows/system32/Config/System you can attempt to repair this file by starting windows setup using thhe original setup CD-Rom. Select ''r'' at thefirst screen to start repair.
    Genius:
  • 1,226 Answers
You can repair that by booting your system using the CD ROM and the select to repair windows.
If ever this will not solve then;
You should backup your files and reinstall the windows operating system.
In installing operating system you need the following:
1 windows bootable disc/ Operating System REcovery Disc
2.Cd /DVD rom
Boot your system any of this CD/DVD disc and then follow the on screen instruction.
After installation, don,t forget to install the drivers of your system that was enlosed in your system.
If ever there problem arising this solution please notify me for further support.
Posted on Jan 22, 2008
Registery cannot load hive file/systemroot/system 32/config/software or its log of alternatice is corrupt, absent or unwritable on compaq presario2227US
Solution 1
Requires some tech skills:
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Solution 2 Reinstall Windows Xp
Jan 29, 2014 | HP Compaq Presario CQ60-249US Notebook
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Problem with OS. How can I fix? Net book states - Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM Can you help? Thanks Philip
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change C:\Windows to the appropriate windows_folder if it is a different location.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 03, 2010 | ASUS Eee PC 1005HAB Netbook - Intel Atom...
I have a asus eeepc 900 netbook.suddenly it stop booting & everytime showing"windows could not start because the following file is missing or corrupt:Windows/system32/config/system.You can attempt to...
/WINDOWS/SYSTEM32/CONFIG/SYSTEM
You can attempt to repair this file by starting Windows Setup using the original Setup CD-ROM
Select “r” at the first screen to repair
So then i click r at the first screen and nothing happens...It keeps on repeating to repair on and on with the same message after i clicked r. I can't even access to the window...what can i do???
Jun 15, 2010 | ASUS m6n Notebook
My desktop shut down and is asking me to re install a 32 windows file. What is this and how do I fix it?
Hi, This normally means that a windows file from the system32 folder is missing or corrupt. You will have repair that by using your operating system cd and go to repair when prompted. If this does not work you may have to install a clean copy of your operating system.
Apr 10, 2010 | HP Pavilion a1220n (A1220NED904AA) PC...
I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 20, 2010 | Toshiba Satellite Pro L300 Notebook
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
My tecra 8000 fails to boot cannot find config sys
Originally Posted by Don this problem occurs when you try to update drivers in the computer..sometimes windows XP cannot update the driver and that corrupts system.ini file as it has a lot of bad entries..Due to this you will get this error mesage..No its not due to virus.its due to an attempt to change system.ini file
That means the System Registry Hive has become corrupted.
There are two ways to get back up and running. The easy way which doesn't always work, and then there is the hard way.
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console2.gif.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Aug 22, 2009 | Toshiba Computers & Internet
Hp paviliondv2050us wont start
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Having problems with my compaq Persario 2500
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
md tmp
md tmp
Oct 11, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
