Question about Kenmore 24032\24036 Top Load Washer
Bolts wont reach
Striped machine and am putting it back together but I cant seem to get the bolts for the pump to reach the sleeve. This first started as just a simple coupling replacement. I have had the whole thing back together but the bolts end up 3/4 inch short. Any suggestions?
Mark
  • 770 Answers
Ok first off i am confused are you sure you have a Kenmore top load ?? You said you had to replace the coupling so i will assume the unit is a direct drive....The pump goes on by 2 clips and fitting it into the motor shaft I dont understand what bolts you are talking about>>????
Posted on Jan 23, 2008
Cuttlas Ciera Wont Turn Over!!!
Sounds like it seized when you shut the engine off after driving it while overheated.
Jul 10, 2014 | Oldsmobile Cutlass Ciera Cars & Trucks
Need to remove the air con pump all bolts are out but won't move
Some mounts have a moveable sleeve in one end that moves in to take up the slack when doing up the bolts. Try using a pry bar or something to lever the compressor out to move this adjuster sleeve.
Apr 06, 2013 | Computers & Internet
Hi, Ive just done a complete rebuild on my crf250 (06) put a new crank, con rod the works, when i put the cases back together the oil pump wont turn, its not that I'm over tighting the bolts or got the...
do you have a clymer manual-it contains detailed rebuild--you know bottom work is really touchy and if things arent done just rite--issues! even pros develop problems
Jan 01, 2011 | 2005 Honda CRF 250 X
The screws to put the crib together are stripped need new ones cant find it is simmons natural meridian collection bought about 4 years ago
if the threds are striped on the screws,,,,or are they "bolts?"
what are the threds like in the nut holders? if there striped as well,,,you need to replace the lot!
Aug 21, 2010 | Toys
Cant put rear suspinsion linkage back together ... 1 bolt wont fit back were it goes ! do i need a vice to squeeze the mount together ???
All the bolts on your suspension unit should slide in easily ,so the bolt is probably bent ,put a straight edge against the bolt and if you see a gap it is bent move the straight edge in four positions on the bolt length to get a good idea.if bent replace,do you do jumps or wheelies .as this will bend the bolts over time. Allso try a different bolt through the hole to check that to.
Mar 04, 2010 | 2003 Honda CR 250 R
Belt water pump
drain cooling system, lossen but dont remove bolts on waterpump pully ,then remove belt by prying back tensioner, (make a drawing of belt route so you can reinstall when done.) next remove bolts holding pump on, now pump should pull off.clean old gasket off block, now put gasket on pump with a little coat of sealant between pump and gasket, now install new pump, reverse direction to put back together, hope this helps, good luck.
Dec 23, 2009 | 1995 Buick LeSabre
Waterpump leaks hoses replaced is water pump part of engine
water pump has a weep hole that tells you it's going bad. replace asap
Aug 31, 2009 | 1996 Dodge Grand Caravan
I cant seem to put the belt back on my whirlpool washing machine its not stretching enough. am i doing something wrong?
slide belt in before short spacer...then over brake lever then pump then put in spacer tighten 9/16 bolts evenly do not use short cut(cut belt) HI HI
Aug 26, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Water pump on 2002 dogde caravan
the pulley comes out with the pump..remove 3 bolts in pump hub..remove all pump bolts and you will need to pry engine back toward driver's side to remove both together..
Mar 18, 2009 | 2002 Dodge Caravan
Need to replace pump/spin belt
this washer your have to take the 2 1/2" bolts on each side the motor then you will have to take 3 star bit screws out of the bottom of the pump slide the pump off then put it all back together and then after mounting you motor and pump back up put it on the transmission puller
Dec 31, 2008 | Amana ALW480DA Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
23 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
