Question about Cyberhome CH-DVD 300 DVD Player
Parental code I use this DVD player for my kid - and out of the blue, we put in a movie (PG), and it says cannot play due to parental block... Don't have the manual or anything anymore - so don't know how to change the code - and have NO IDEA how it would have even gotten changed - my kids couldn't have done it...
  • 4,402 Answers
You can take your time putting in the code. I mistakenly had the impression
you had to time it just right. But no.
Just close the tray with no disc inside, it will say NO DISC.
On the remote, press MENU, the "non-applicable" slash circle graphic comes
Then press 1, (same slash circle), then press 9, and the menu pops up.
My menu says:
Region : 1
Password : ____
Level : 8. Adult
By default, the region number is highlighted. This is where I got confused. I
pressed the control pad on the remote left and right and up and down and
nothing changed the number.
The only way to change the number is to press ENTER on the remote and it
then cycles through all the numbers available. I was never given a chance to
punch in a number, I tried it and it didn't work.
While I was here, I also set my password code and looked through the choices
for LEVEL. I think it is a system to limit the type of movie that could be
played, for instance, if the DVD player was for a child's room, you could limit
the level to G, PG, or PG-13 and it wouldn't play movies rated worse than
that. good luck
please mark the post with a fixya!
Posted on Feb 07, 2008
How can I change the parental control? Somehow the parental controls are set on the DVD player and it will not allow me to play certain dvds without a password
Unfortunately there are no known ways to change the user code. The parental controls are set because it's a DVD player for kids - and you must input the password every time you want to play a DVD.
1369 is the code to allow you to play blocked movies. I still haven't found a way to change the level. Again, you have to input the code each time. I know it stinks, but I guess they didn't think of the parental feature in its entirety.
Jun 24, 2010 | Disney Ramone DVD Player
How to play dvd on ps2 slim
just slide the dvd in like a regular PS2 game and then let it play! if its a PG 13 - R movie then you have to put parental code in but dont worry, if you dont have a parental code then just type in (example) 1111 as the parental code
Feb 26, 2010 | Sony PlayStation 2 Slimline Console
Player won't play certain dvd's
the password is the arrows you have to do forwrd,backward,forward,backward but use the doubke arrow keys. this should work i found the soloution the manual
Mar 12, 2009 | Disney Hannah Montana DVD Player
Tv guardian settings
OK I FOUND IT!!! IT'S 1234, when the parent control screen shows up press the play button then enter 1234 then press play again!!! The movie plays then!
May 08, 2008 | Disney Princess DVD Player
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Oritron dvd4110 player
if you do not remember the code to unlock your dvd ,have a tech lift off the memory chip and resolder it back to its originald position.this will restore it back to normal.good luck
Jan 06, 2008 | Televison & Video
Parental block princess dvd
This will make the player region free which may also reveal a menue that either gives you the oppertunity to clear the password or clears it automatically...
1. Turn on the Player (with no discs in)
2. Press the Open/Close button (leave it open, like if you were yet to insert a
3. Press the Display button (on the bottom of your remote control, close to the
numbers 0-9)
4. Press the following sequence: 1,3,6,9.
5. Press the number of the Region you want (0 for Region free)
6. Turn off and on your player.
Dec 12, 2007 | Televison & Video
Dvd troubles
Same problems with my unit.  But, try this... I think it worked.  First, you can not get to the setup screen for the unit with a DVD in the player.  So, remove the DVD first:  Unplug the unit, wait a few seconds, plug it back in.  Then hit the DVD open button and remove DVD in player.
I think the issue with not reading certain DVDs is a problem with the "parental control" on the unit. Without setting parental control there were a few DVDs I could not play and sometimes (not always) I was asked about parental control before a movie would play.  At the Sony Blue DVD screen, select Setup on the remote control.  Select DVD setup and get to Parental control.  Set a password.  This will then take you to a "rating" screen.  By setting the rating very high (I set mine for #8) any movie should play without needing the password.  With no password set, you can not change the "rating" and hence mine was set at #1 (kids).  It seems to have worked for now anyway.  Good luck.
Oct 14, 2007 | Sony SLV-D300P DVD Player/VCR
Soundstorm car dvd player
This is from the soundstorm website: If your DVD player shows a "Parental Code" on the screen. Here is the factory default code. It is 3308. Once you have this code, you can go into the settings and change the level to whichever level you like. Here is a break down of the levels: Level 1 = G Rated Level 3 = PG Rated Level 4 = PG 13 Rated Level 6 = PG-R Rated Level 7 = NC-17 Level 8 = Adult Level 0 = No Parental
May 29, 2007 | Soundstorm SDVD-100 Car DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
174 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
