Leaking from water pump and timing belt is slashded up
Since you'll have to take it apart to replace the water pump; they say to also plan on replacing the timing chain while you're in there. It's the most opportune time to do so, rather then wait to have a problem with it, and have to take the engine front all apart a second time.
If you are losing antifreeze out of the water pump, then that is a sympton telling you it's time to replace the water pump. When you say the timing belt is slashed up, do you mean the serpentine belt that runs the power steering pump, ac pump, alternator, and water pump or have you actually torn the engine apart enough to see the timing belt?
If you in fact mean the serpentine belt, chances are it's torn up because either antifreeze got on the belt making it slick enough to get off track and when they get off track, they can get slashed up pretty quick.
Good Luck
