Question about Lexmark JetPrinter X1185 All-In-One InkJet
I need advice asap about lexmark1185
I plugg it into computure now and the wall socket power is on has green lite indecating that power is on .So now I mash scan it does nothing . Next I smash Ismash color copy nothing happens then I mash black copy and still does nothing. what do I do next
  • Anonymous Feb 02, 2008
    i need to install my lexmark jetprinter X1185 but do not have installation CD
My lexmark x1185 should be trying to print the envelope on the very right hand side of the entrance. However, when I lay the envelope on the right hand side of the entrance it will not print. The printer is typing on the left hand side of the entrance (the left hand side of a regular size paper). I cannot find how to change this problem. Please help
Posted on Jan 22, 2008
What are the colors in a vga monitor power cord?if white green and black, which is what?
in all power cords - green is ground, and white is neutral. black is always hot.
measuring with a voltmeter, while cord is plugged into the wall socket (presuming power is available in the wall socket), you would measure 115-120 volts across white to black or ground to black.
zero volts between with and green.
regards,
Mar 24, 2018 | Vga Computers & Internet
I have one toshiba equium laptop, in this laptop not switch on but led is working. can u please advice me asap
Can you give me more details please as I dont understand your question properly.
Do you mean the power light on the front left is lite but when you press the power button nothing happens?
Feb 22, 2011 | Computers & Internet
Have a Rinnai thru-the-wall 1001f. Has run flawlessly for over 15 years until now. When the heater runs, it runs fine. But we find the heater is turning itself off more and more lately. On the front panel...
I had the same very exact problem and got my hands on the service manual for the Rinnai 1001 series heater to solve it. As fas as the spark gap it should be 3mm but I went through a lot of tests of the components and found that Solenoid 1 coil was open. It should read about 1.3K and mine was completely open. Solenoid 1 is the one against the back cover. You'll need a small inspection mirror to see it but it is part number C23B-23. REMOVE POWER/UNPLUG FROM THE WALL FIRST then pull the plugs off all of them and check the resistance of the coils, they all should be about 1.2-1.3K. If you havent already found the answer I hope this helps.
Also check the pressure switch, bottom right side in the front. Its a disk, diaphram type device about 4 inches in diameter with a microswitch on it. That switch should close, zero to 1 volts across it, once the combustion fan starts up and builds a little pressure. If it doesnt it could be the switch or the intake or exhaust parts of the flue or filters are clogged.
Jan 16, 2011 | Heating & Cooling
How can i open it and where to find the charger ?
  1. Connect the power cable to the jack on the sync cable adapter
  2. Connect the 26-pin device plug of the sync cable to the 26-pin connector to the bottom of the device.
  3. Connect the power plug to the grounded wall socket.
The LED indecator will start to flash green as soon as it begins to charge.
Jan 15, 2011 | ASUS Mypal A730W Windows Mobile 2003
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Ds lite green light comes on but nt the screens
For me it was a loose Wireless board - pushed it back into place and boots fine.
Mar 13, 2009 | Nintendo DS Lite Console
Will Not Power Up
the middle one with the A is Caps Lock....
Try removing the Battery from the System.... There is a power indecator on it....... Push the button on the battery Five lights full battery.... No Light Dead.... If Dead Your Power supply might be at fault....
Is the power Supply Light Lit? If No.... Bad Check connections..From Wall to Brick ect.... Still No... PSU Looks Bad....
Jan 07, 2008 | Dell Latitude D600 Notebook
Lexmark JetPrinter X1185 All-In-One InkJet Logo
93 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
