Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Can't get it to work
I have plugged device in to proper usb port and electrical outlet. can't find device being seen by computer. did not come with drivers do I need them if so where can I find them.
    Scholar:
  • 75 Answers
What operating system are you running? Windows Me or older has troubles finding plug and play external hard drives sometimes. If so look up some how to's on google for installing your model of external hard drive on to the operating system you're using. Although if you're using XP or Vista you may have an issue in your Device Manager. In that case you will need further instructions.
Posted on Jan 22, 2008
6ya staff
SOURCE:
Device will not work with 3.5mm usb connection. how do i fix
Depends on what 'will not work' means.
Basics first:
1) Is the cable good - plug a USB device that you know works to your computer with the cable. Can you see that device from your desktop?
2) Is the USB port live and functional? With a known good cable and external device, does it come up? (Might combine with (1) if you can get the device + cable to come up on another computer or USB port. If it works on another system, do you get any tone or indication from your computer that something has been plugged in? Go to the USB devices page - it's in Hardware Manager in Windows, and check that the port is being seen. If you're getting a not-in-use or warning icon for the port, you may need to go update the driver.
3) If you have the documentation, or if your GPS still has a manual (or an external charger), see how much current the device draws on the USB (it should be in milli-amps or Amps (mA or A). If it's substantial, you could be overloading the USB port with the power draw. Try plugging into an external, powered USB hub that is attached to your computer. That may do the trick.
Good Luck!
Nov 09, 2015 | GPS
Where can I get a replacement for my 2 front usb ports on my optiplex 760..they are not working??
I've never seen 2 front USB ports that were bad. I've seen 1 that was defective because the USB device that was plugged into it was broken off. However in that case it caused the power supply to short out and prevent the computer from powering on. Here is a link to your model:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_optiplex_desktop/optiplex-760_Service%20Manual_en-us.pdf
If the USB ports on the back of your computer work then the front ones should too unless there is a connector dislodged to motherboard. All USB ports use the same circuit.
Jan 29, 2013 | Dell OptiPlex 760 MT Desktop Computer
My pc wont continue booting because of usb overload
what makes you think its usb overload ?
Check your computer's power cable and the power cables to any devices connected to the computer. Make sure all cables are firmly plugged into electrical outlets and into the computer and other devices. If you have an extra power cable for your computer, swap it in to see if your computer's power cable is the problem. Remove your computer's battery, if it is a laptop, and connect the computer to a electrical outlet to see if it will start up. Sometimes a discharged battery will prevent a laptop from powering up. If your laptop still won't power up, remove the power cable, replace the battery and try to run the computer off battery power. Unplug your computer and plug a lamp or radio into the same electrical outlet and see if that device works.
If the lamp or radio doesn't work, the outlet is the problem. Unplug your computer and open your computer's case, if it is a desktop system. Look for loose cables, cards and connections and attach them firmly. Blow out any dust with a can of compressed air. Also, check your computer's memory chips to make sure they are all plugged in and seated properly. Close the case once you are done and plug in the computer. Disconnect any USB devices connected to your computer and try to power up the system. Sometimes a USB device not connected properly will stop a computer system from powering on. Disconnect any new devices recently added to your system. Sometimes new devices will conflict with other hardware within your computer and cause an overload on your computer's power supply. Disconnect any other devices connected to your computer such as the keyboard, mouse, monitor, printer or scanner and plug your computer into a electrical outlet by itself. Check to see if the computer works. If does work, shut it down and connect just one device, such as the monitor. Turn on the computer and monitor and see if everything works. Continue connecting devices until you find the one that is stopping your entire system from powering up. Hope it helps.
b>
Jan 23, 2013 | Computers & Internet
I CAN NOT CHARGER MY DEVICE IN USB
USB connection cables comprising of ports on computer telecommucnations devices are versatile outlets to managing multimedia. First the USB port on the device makes device to device connection where resoruces can be shared among several function requests. Second, the USB port on device least allows to derive power charge from another device only has to be attained from power outlet. For example, while a device is plugged into another device for media resources sharing is least like to attain power charging simultaneously. First use the USB port to power charge from an outlet to attain required functioning status. Circumspectively, the devices that have USB ports has several functions either as media resource sharing also for power circuit charging only each separarete process is attained where it is impossible to power charge a device while using the same port to derive functionality.
Feb 18, 2011 | Computers & Internet
One of my usb ports won't work properly. If you plug something to it for longer than half an hour the usb port stops recognizing the device you plugged. I have an hp dv7 4190us laptop.
Start with the normal fixing methods, including uninstalling the drivers for your devices and reinstalling them. if That didn't work! Next try System Restore thinking that maybe you have installed something and it caused a conflict with the USB system drivers. That didn't work!
go to Device Manager and uninstall all of the devices under USB Controllers. Restart the computer, reinstall the USB drivers,
You may also see in Device Manager that the device shows up as an "Unknown Devic
last fix for the problem? Well, apparently it's a super simple solution! No need to edit the registry, uninstall drivers, or anything of that sort.
Simply UNPLUG YOUR COMPUTER FROM THE POWER SUPPLY. Yes that's it! Note that this does not mean just turning off your computer because modern computers don't really turn off when you press the power button as the motherboard still gets power.
First to explain, the motherboard is where all of hardware of the computer is connected to, including the USB ports. Sometimes the motherboard needs to be "rebooted" also because something can go wrong, i.e. all your USB ports suddenly stop working. The small microprocessor on the motherboard will reload the drivers and your USB ports should be back to recognizing all devices!
So first turn off your computer using Shut Down or pressing the power button and then UNPLUG it from the wall outlet. Let it sit for about a minute and then plug it back in.
Jan 10, 2011 | HEWLETT-PACKARD HP Pavilion DV7-4190US
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Simpletech 160mg pinifarina wont work
sounds like a corrupt driver. Go to device manager, and see if the USB tree has a yellow exclamation, if yes, uninstall USB driver and reboot.
Jul 25, 2009 | SimpleTech SimpleDrive 160 GB External USB...
Gateway USB ports stopped working
So maybe you need to install the drivers for the USB device you are trying to connect. Also, with the computer off, try cleaning all USB ports and plugs. You can buy electrical cleaner in a spray can at Radio Shack. Let it dry thoroughly before powering up. But to me it sounds like a driver problem. Unless maybe your USB BUS is going bad.
Jan 06, 2009 | Computers & Internet
Printer not configurating with computer
Two problem that occur. You plugged in the new printer before installing the software. If you have XP it will go and install it with it's drivers. Your printer wants it's own drivers. A second problem I've seen is having too many devices plugged into USB ports. If the software was installed properly, remove non-needed USB devices and re-boot the computer. If the printer works, look into purchasing a "POWERED" USB hub. They cost between $5-$25
Mar 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Connect USB Port will not close.
I've seen is having too many devices plugged into USB ports cause this problem. If the software was installed properly, remove non-needed USB devices and re-boot the computer. If the printer works, look into purchasing a "POWERED" USB hub. They cost between $5-$25
Mar 07, 2007 | Lexmark X4270 All-In-One InkJet Printer
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
117 people viewed this question
Top Seagate Computers & Internet Experts
Ekse
Alun Cox
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
