Question about Braun 360° Complete 8985 Electric Shaver
Shaver will not charge or clean in the base
When I place my shaver in the base the auto select modes for cleaning status will not light up. It will also not charge in the base. The light indicating the status of the cleaning cartridge is on, so I know there is power to the base. If I push down on the shaver in the base the lights will flash briefly and a clicking noise is heard then nothing. What is the problem?
  • 14 more comments
  • Anonymous Jan 29, 2008
    Razor will not clean itself in the base - it just sits there doing nothing!
  • Anonymous Feb 15, 2008
    Same problem. Wouldn't work for months, then yesterday, Bam! Worked. Today. Nada.
  • Fisherbody Feb 22, 2008
    SAme problem - can't charge in base and have to plug directly into razor - can't run clean cycle either - tried "fiddling" and once was able to get base to recognize presence of razor, but not again since -- any solutions? or does Braun sell just "base" replacement?
  • Anonymous Mar 04, 2008
    Same problem. Base suddenly stopped working after 1 year.
    Same problem. Base suddenly stopped cleaning/charging after 1 year service.
  • Anonymous Mar 25, 2008
    the charge works, but not the cleaning cycle.  I have new cleaning fluid cartridge, but no cleaning takes place, and the status light for any type of clean status does not light up.  Is there a reset button?
  • Nixon73 May 15, 2008
    I'm having the exact same problem. I fiddled with the razor in the base and got it to recognize the razor. the next day when I took it out the razor was very hot. Doesn't seem right at all.
  • Kerry2 May 30, 2008
    No cleaning lights and no cleaning takes place. No charging lights. Blue light on top comes on, so it's making contact I figure. Turned it on/off, cleaned the cleaning chamber. Foil replaced in last 4 weeks. Replaced cleaner fluid. No change.
  • Anonymous Jun 04, 2008
    Exactly the same problem. I tried a second base, same thing, so this is apparently a problem with the shaver itself not communicating with the base. I've had it repaired once already, worked for about 2 more months, failed again.
  • braunjnk Jul 27, 2008
    Similar problem. Had shaver for 6 months. Am careful with shaver - never dropped or anything close. Place shave into holder after every shave. No animals, kids, or anything else near it. The problem: the light showing connection is made stopped coming on two weeks ago. Looks to me that the contacts on the back of the shaver are supposed to electrically connect to two metal foils inside the holder, one of which appears to have the metal surface scraped off, perhaps hence no connection. My impression is that Braun is using substandard/shoddy connections. But if I have this problem, then lots of others should have it also. ??
  • David Lenchner Oct 09, 2008
    Maybe this is built-in defect. My shaver which is now a little over a year old, was working fine yesterday but now will not light up any of the cleaning lights, just the status of the cleaning fluid. If anybody discovers a cure, please let us know.
  • Anonymous Dec 13, 2008
    Exactly the same problem. Cleaning unit just won't light up
  • Eddie Braun Feb 14, 2009
    Same problem. If I jiggle it around the lights come on, but when I release the shaver they usually go out again. Not a cheap razor either. Purchased at Costco.
  • Anonymous Mar 15, 2009
  • ungulation Mar 30, 2009
    Same problem, the shaver will charge directly from the power adapter, but not from the cleaning base. The cleaning base does have power because the level lights are on. It looks the base does not recognized the shaver.
  • briankthomas May 05, 2009
    I'm on the third cleaning base for my 8985. They are obviously defective. DON'T buy it!!! Same problem. Place the shaver in the base and the lights stop lighting up and it won't clean. Seems like it takes it about a month or so, then it stops working. Braun has been good about replacing the base, but seems like a band-aid. Same problems with all the bases.
  • 97 Answers
All you have to do is take the base apart. Turn it upside down, and there are two plastic clips on the rear portion of the base. Press them in with a key or screwdriver and wiggle the base a bit to remove the inner portion from the outer shell. Make sure you unplug the unit and remove the cleaning cartridge before doing this. Once it is apart, place a small wedge underneath the portion of the electric contact that sticks out to touch the shaver, and press the back of that portion out so that it slightly bends the contact strip and makes it stick out a little further. Then remove the wedge and put the base back together. It will work again, as the contacts can now protrude to touch the shaver and run the cleaning and charging cycle.
Posted on May 09, 2009
  • Gary
    Gary Nov 07, 2010
    Thank you for this information. One of the contacts had somehow managed to get pushed back far enough to no longer connect to the shaver when installed. The only way to really correct it was to take the base apart, as you suggested. It does take some time to extract the inner portion, even after pressing the release tabs. It's in there very tight. But careful pressure without going too far (the mechanism is fragile enough to break) manages to get it free. It's too bad the contact strips can't be easily removed. It appears that they are held in by a one-way tab. Anyway, bending the contact strip as you suggested seemed to do the trick. It's not perfect, but it should hold as long as you don't put any undue pressure on the contact point. If I have to do it again, I'm using epoxy glue to secure the contact strip.
The problem seems to be with the "memory" on the device. If you remove the internal battery from the unit for 2-3mins (might be a smaller amount of time) and replace, the device goes right to "intensive" and starts the clean cycle.
Here's some steps:
  1. At the bottom of the shaver (around the slot for charging) is a plastic cover. Get a small flat head screwdriver to pop it off. The piece is like a frame around the slot if that helps.
  2. The sides of the shaver (the silver grips) should pop off with to locking mechanism really.
  3. Unscrew the 4 torque screws and separate the top from the bottom.
  4. Since the shaver is now open, give it a cleaning. I cant believe just how rusted and gunky mine was. So much for self cleaning!
  5. Now at this point just remove the battery bottom from the shaving top. This is all I did for 2-3mins.
  6. Just make sure all the contacts are clean and flexible if they are the spring type.
  7. Put it all back together.
Hope this helps whoever tries it. It did for me.
Posted on Feb 02, 2009
  • 1 more comment
  • Eric Moss Oct 18, 2011
    Mine was not charging in the stand nor cleaning. Did what you said. Worked like a charm. Thank you. Saved me upwards of $200.
  • nprout566
    nprout566 Dec 26, 2012
    I dropped mine about 2 years ago and it never turned back on. I tried your steps and whadya ya works! Unfortunatley I metal piece fell out and I do not know where it goes. Any ideas?
  • manish74 Apr 14, 2013
    awesome ..worked for me as well..thx
Give up on Braun, they might appear to be a German brand but the quality has gone in the krapper.
My screws RUST in the shaver, this is the THIRD braun that is fucked up in communicating with its base or it quits (different models) ...
imply put, the MBA weenies instead of the German Engineering folks are in charge of the company and that is the end of another good brand.
Me ... i am so dsgusted, I went out and bought a first quality set of straight razors and am now getting the best shaves of my life.
Kiss my face shaving goo, high quality straght razor, oiled and strapped well, hot towel on face to soften the face hair, and wow, it is soo smooth and soo nice ... makes the electrc look lke junk ... better yet, no changing, no failing, and I can do anywhere, (except on a bouncing rutted road as I drive)
Spent over 800$ in the last decade on electric shavers, enough is enough.
Back to the cold steel and a good shave again ...
Posted on Aug 13, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
First-unplug from current, second remove cleaning cartridge, third spray Kroil penetrating oil making sure oil goes behind metal contact points, allow twenty four hrs for penetrating oil to function then repeat every three months for no problem service. This has worked for me six plus years, yes Kroil brand oil is expensive, however, this oil achieves desired results.
Posted on Sep 19, 2015
    New Friend:
I actually bought a new power cable for mine so I could just forget about the dodgy base, but before it was delivered I realised you can just pull the power plug out of the cleaning base itself and plug it directly into the shaver... Easy to know if it's the shaver or base's fault at least!
I let the shaver charge on the cable directly for a few mins, took the cleaning cartridge out of the base and replaced its power cable. Flashing red light for Cartridge- OK good, replace the cartridge. Shaver back in the base, large elastic band to stop the thing popping back up (lol another Braun problem) and it automatically selected Clean once it had contact.
Hope this maybe helps avoid taking the shaver apart for some :)
Posted on Oct 14, 2014
    New Friend:
You need to Unscrew the 4 torque screws and separate the top from the bottom.after it give cleaning it. remove the battery for some mints.close it and then try again, i hope it ll be working.
Posted on Feb 19, 2013
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
I have had numerous of these Braun shavers, and only occasionally have had any problems period, and if you work with the charging base to get it to reset at times, you will probably get it to work, after some diligent care.
All things need some help after a while of constant use, just like your car needs to be serviced. All the oil and dirt around the shaver needs to be cleaned well, to keep it working it's best.
These shavers are still the best for the money.
Posted on Oct 05, 2009
My base will clean my shaver , but after doing so wont reset itself. So it just keeps doing the intensive cleaning every time I put it in the base. Also the base will not charge the shaver. I have to plug the cord directly into the shaver I punched it a couple times and now it seems to charge again, Still havn't tested to see if the cleaning cycle resets itself or not..
Posted on Mar 28, 2008
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at See link below
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
Can't get the 7526 cleaning arm to stay down on the shaver for charging, cleaning, etc. Is there a sequence e.g. hold the arm down then select a cycle, or select then push down? What is the blue button...
The locking mechanism in the arm is broken. This is a common problem with your model. To repair it you will need to purchase a replacement part. You will find the part at See link below
If repairing your existing clean and charge machine is not an option, you will find the entire machine available at the link below
May 08, 2011 | Braun Syncro 7526 Electric Shaver
Braun 8585 shaver, charges fine, cleaning cycle acting strange where it thinks the razor is clean, but it is not. When new it cleaned at some level every time put in the cleaning base. Now it very...
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at See link below
Oct 09, 2010 | Braun 8585 Electric Shaver
Clean and Renew stand for braun 8595 does not seem to cycle properly...after shaving and placing in unit, it randomly seems to clean and is stuck on cleaning cycle (normal light blinking, no charge) I then...
The circuit board on the shaver may have become faulty. One thing you can try is to fully charge the shaver first, directly connected to the outlet, and then try using the cleaning base. Also, be sure that the fluid level is sufficient. Lastly, you may be able to buy a used but working condition cleaning station off of eBay. New replacements are a bit costly.
May 10, 2010 | Braun Activator 8595 Electric Shaver
Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
it sounds like your clean and renew base will need to be replaced. you will find a replacement at
Dec 17, 2009 | Braun Activator 8595 Electric Shaver
Cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
Oct 27, 2007 | Braun 360° Complete 8985 Electric Shaver
Braun 360° Complete 8985 Electric Shaver Logo
11,199 people viewed this question
Top Braun Health & Beauty Experts
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
