Question about Lands Phones
Icannot get a dial tone - Lands Phones
  • 13 more comments
  • Anonymous Feb 15, 2008
    Phone is only 6 months old and I have no dial tone.
  • ronvick Mar 17, 2008
    No dial tone, but I hear the background sound in the room; tv and voices
  • Anonymous Apr 30, 2008
    Brand new 2 phone system. No dial tone on either phone.
  • aspires002 Jun 25, 2008
    I cannot get a dial tone. I have unplugged the phone and batteries, waited, and re-connected everything, waited, and still no dial tone. The other features on the phone are live.
  • mjbergin Jul 24, 2008
    no dial tone from both phones...everything has been unplugged and replugged, just like the other posts..everything else on phone works
  • tgrimmett20 Jul 27, 2008
    The electricity went out twice this morning and although all other electronics were restored & the phone appears to be back to normal, there is no dial tone and when people try to call, they say there is a constant busy signal. Please help.
  • mjames735 Aug 11, 2008
    cannot get a dialtone all other function are working, lcd light, clock, and time. what is the problem?
  • lotusabstrac Aug 18, 2008
    I can't get a dial tone, but I can hear myself reverberate. Also my secretary can hear me through her phone
  • besswills Nov 21, 2008
    NO dial tone, It was fine Wednesday, then Thursday morning it was gone. How can I get the phone to work?
  • jylj1 Jan 07, 2009
    Today we got lots of static, then no dial tone. Is the base unit dead?
  • Anonymous Jan 20, 2009
    no dial tone,can'n dial out,rings but no answer
  • Anonymous Jan 27, 2009
    no dial tone on my cr56
  • Anonymous Jan 28, 2009
    everything is pluged in but still no dial tone. i switch it to my old phone and get a dial tone. just not this onel menu and options work.
  • Anonymous Mar 26, 2009
    no dial tone
  • Anonymous Apr 16, 2009
    I turn my phone on but i cannot get a dial tone whats going on???
We had the same problem. we called the operator who found a problem on the line.
Posted on Apr 26, 2008
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Gigaset AL110 REGISTERED , CANT DIAL OUT OR IN
Is there a dial tone? And have you tried another phone? If there is a dial tone make sure the phone is set for tone dialing. There will either be a switch on the side of phone for pulse or tone, set for tone. or go into the menu and look for it there...
Apr 14, 2014 | Lands Phones
Dial tone on speaker-phone but no dial tone on line 1
Either button mapping or no dial tone at the system cabinet. If your desplay sas CO1 and you have no dial tone, go to the sytsem cabinet ans swap the modular plugs for CO1 and CO2. If the No Dial Tone moves, "mus be sumpin wrong wit yo lines".
Carl
Aug 13, 2010 | Panasonic KX-T7730 Corded Phone
No dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Sep 04, 2009 | Vtech Lands Phones
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Dial Tone - Number Dialed does not go through
The problem is possibly the keypad on the phone. Try another phone , preferrably a standard corded phone. If you still cannot break the dial tone, then the problem is with the telephone line (phone company)
Mar 28, 2008 | Lands Phones
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
489 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Lands Phone Expert? Answer questions, earn points and help others
