Question about HP Color LaserJet 3500 Printer
Hp laser jet 300 printing
The printing quality is great however I get in the middle of the whole page dots. The distance is one inch. What can I do. The process cleaning is not helping.
  • sousinga Jan 23, 2008
    the dot isvery small the repetition along the whole page vertically is 1.1 inch.
    Now I have in addition a repetition of film vertically on the page . starts between 2.5" to 4.5" of the width page. it ends little bit further from the dot.
  • Markwilcox Feb 18, 2008
    This printer is in working order except it leaves a black stripe down the center of the page. How do I get rid of this?
  • 26 Answers
It is one of the cartridge.
Posted on Jan 22, 2008
The page prints with a regular black spot down the middle.
Evenly spaced black dot down page could be either the transfer roller, fuser or drum unit. If you measure the distance you will know which, but most common is the drum unit. If you have another drum try it, your problem will likely go away. If not measure the distance from the start of one dot to the start of the next and post that meaurement.
Mar 31, 2011 | Brother HL 2140 Laser Printer
While printing in black middle of page fades out both sides of the page print well. this is about a 1 inch fade out in middle of page.
Replace the drum of the particlular color cartridges. To know which color you have to print in single color one by one. If problem persist then replace transfer belt .
Jan 05, 2010 | Samsung CLP 300 Laser Printer
The print on the bottom half of the page is unclear - top half is great, but quality deteriorates near middle and bottom of page
The suspected problem in the imaging unit. If you have problem in one of the color (likely black) Then you have to change the black developer part in the imaging unit
Oct 21, 2009 | Samsung CLP 300 Laser Printer
How do I clean the rollers on my laser jet printer, it prints with a long black strip in the middle of the page. Hp laser jet 1320
Most likely the heat roller is breaking down in the fuser. The fuser must be replaced. But before going that far, replace the toner cartridge, as it may have a bad cleaning blade. 85% of all print quality defects are cartridge related. This particular model of machine has a very brittle heat roller that more often than not wears out prematurely. This is true across the board for all of the newer HP low end laser printers unfortunately.
Sep 30, 2009 | HP LaserJet 1320 Printer
Hp laser jet1100 prints white lines
Hi ejazmusavi:
Try this.
Toner/developing cylinder 37.7 mm (1.48 inches)
Toner/primary charging roller 37.7 mm (1.48 inches)
Heating element 56.5 mm (2.22 inches)
Transfer roller 45.2 mm (1.78 inches)
Pressure roller 62.8 mm (2.47 inches)
Toner/drum 75.4 mm (2.97 inches)
Feed roller 55.1 mm (2.17 inches)
Hope this helps
May 29, 2009 | HP LaserJet 1100 Printer
Black dotted lines accross the whole page
Jason,
If the whole page is covered with stuff that's not supposed to be there, and that stuff sometimes changes shape or color on each page. then you look to the DRIVERS and connection 1st. Corrupt printer memory can also cause this.
If the corruption tends to be consistent across print jobs and it's only on certain spots on the page, you can start to look for mechanical defects.
Can you describe in more detail?
Jul 18, 2008 | Samsung CLP 300 Laser Printer
HP Laser Jet 2200 dtn - Print Quality
For troubleshooting "ghost printing" use "LaserJet 2200 repetitive defect ruler". Measure the distance of 'ghost' figure from the 'original'
Try this link:
http://www.printertechs.com/tech/repdef/ruler2200.php
Jan 05, 2008 | HP LaserJet P2015dn Printer
Laser Printer Cleaning
Does the dirty background get lighter as you print additional pages? Have you tried a new cartridge yet? Unless your toner cartridge is leaking toner (you?ll see toner on the inside of the printer or leaking out if you remove the cartridge and shake) a simple cleaning is probably not the answer. Let me know and we'll pick up later.
Feb 28, 2007 | HP LaserJet 4100n Printer
HP Color LaserJet 3500 Printer Logo
53 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
