Question about Epson Stylus C86 InkJet Printer
Epson stylus photo 830 my printer is only printing red wwith the word new zealand at the top
Have reinstalled it and put in a new colour cartrige can any one help me regards bob
  • 353 Answers
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Feb 28, 2009
Stylus R220. Just replaced the black ink and it still won't let me print. Keeps saying REPLACE CARTRIDGE. I'm using a Mac. Supply Levels Utility is completely useless. Says Information Not...
Try to clean cartrige and cartrige carrier conector place with soft erager.Then put cartrige into cartrige holder then gentaly push top of the cartrige sothat a `cat' sound happend, then turn on printer.
I think you will relive
Thank you
Sep 06, 2011 | Epson Stylus Photo R220 InkJet Printer
place the document in side, by the left hand top you will see copy, with two different buttons one is coloured and the other, click on the coloured to get coloured document and click on the black to give you black and white, just once and make sure there is paper in the feeder, thanks
Jul 13, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
Ink cartriges not being recognized by printer
It is not uncommon for an Epson printer to fail to recognise Epson cartridges. It is either due to failing to go through the proper cartridge replacement cycle properly, or more seriously, due to a communication problem between the cartridge and the main board. To fix the first, simply go through the cartridge replacement cycle again (see your manual how to do this before the cartridges are empty). Simply take your new cartridges out when told to, and put them back in again when told to insert the "new" cartridges. If it's the second problem you need specialist help, or simply sell your printer on e-bay for what you can get.
Dec 17, 2008 | Epson Stylus Photo 830 InkJet Printer
Epson Photo R265 Lines every 2.5 cm
If its doing it on all types of paper despite of any setting on printer driver, chances are you are having a hardware issue with the product.
pls try this site: try use passcode; lock
only applies for US printers
pls dnt 4get to rate soln hope the site will help thanks
Apr 06, 2008 | Epson Stylus R265 InkJet Photo Printer
Print the files through epson stylus photo 380
I think you need to add more details to your question. You are unable to print in what system or OS? Windows XP? Vista? Mac? This would help you find a good solution to your problem...
Dec 09, 2007 | Epson Stylus Photo 830 InkJet Printer
Cartrige refilled reset but no colourprinting epson stylus c66
Clean the print head/Control panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Nov 02, 2007 | Epson Stylus C66 Inkjet Printer
Colour cartrige not work epson stylus c66
If the red light is flashing it means one of your inks are low
Epson Stylus Photo 830 Only printing first 2 inches of page
try uninstall your printer and then install it again.....
Oct 25, 2007 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
365 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
