Question about Samsung SyncMaster 750S Monitor
Sam.SyncMaster750S control buttons not responding
My monitor has been in use for 8 years and is probably just old(?).I wanted to open it myself and try find out if there was something obvious to clean from inside but fortunately for the monitor and probably for me too, I never managed as there are no screws visible.How do you open the thing,wonder?
Thanks for any happy suggestions.
    Problem Solver:
  • 3 Answers
First, be aware that the flyback xformer can carry a 50,000 volt charge that can arc to anything grounded. Unless you are possitive the chasis is not hot, I'd forgo pulling it apart.
That said, if you turn the monitor on its face and remove the stand. You'll see two screws on the bottom corners of the monitor housing. Remove them. Next, turn the monitor upright with the screen facing you. you'll see two VERY small openings along the top edge of the monitor bezel. Insert a small flat-headed screw driver into each opening, and press gently down. You should hear the locking tabs release. DO NOT pry the case as you will damge it. With the screws out and tabs released, the case will easily break apart.
Posted on Apr 14, 2008
My neighbor's remote opens my garage door ever since I added a keyless keypad. How can I fix that?
probably not
talk with the manufacturers of the remote device you have installed and see what can be done
there will be a method of resetting you device to respond only to your remote but it will require tech knowledge that the manufacturers will have
May 07, 2017 | Building Materials
Sam is 5 years old...his older brother Tom is 3 times as old as Sam...when Sam is old will Tom be?
Well, Tom is 3 x 5 = 15 yrs now. Sam has 15 yrs to go to 20. Then Tom will be 15 + 5 = 30 yrs.
Or, Tom is 10 yrs older than Sam now, so when Sam is 20........
May 15, 2015 | GPS
Jenn-Air Range displaying Error F1-8
Did not find an error code "F1-8"
I did find these. Seems that about everything that can go wrong with a Jenn Air is related to the clock.
Sep 22, 2017 | Jenn-Air JES8850AAS Electric Kitchen Range
Whirlpool quiet partners II normal light flashing
A rapidly blinking LED over one of the keys of the keypad (or sometimes a "dead" keypad/console)
To determine if the control or keypad is faulty, do the following test:
1. Unplug dishwasher or disconnect power.
2. Open the dishwasher door.
3. Open console and disconnect the keypad ribbon connection from the control (at P1).
Make sure all other connections are made.
4. Put console back together. Do not close the dishwasher door.
5. Plug in dishwasher or reconnect power.
6. Wait 5 seconds.
7. Close dishwasher door.
8. Monitor the control's response:
If the control is OK (no longer sees shorts with the keypad unplugged),
it will respond by turning on a Drain Motor for 2 minutes.
Check and/or replace the keypad if the control responds OK.
If the control is not OK (still sees shorts with the keypad unplugged),
then the drain motor will NOT respond and will remain off.
If no response, replace the control.
Dec 18, 2013 | KitchenAid 24 in. KUDI02IR Built-in...
Gateway FPD 1730 (mfg June 2004) On start-up, monitor flashes bios screen for less than half a second, then flashes the Windows XP logo for less than half a second and then stays black, no image. No...
All support is finished for XP years ago. The system is 13 years old and well past it expected life. Average is 8 to 10 years on a shop bought unit like Gateway, 12 years on a custom build.
I am thinking you probably have a dry joint on the board behind the switch as holding the switch makes the monitor work.
My advice though is a new computer running Windows 10, technology moves on in hardware and software.
Mar 08, 2017 | Gateway FPD 1730 17" Flat Panel LCD...
Sega genesis 2 isn't responding to controllers
Its probably so old that the buttons are sticking and/or broken
Feb 25, 2010 | Sega Genesis Console
Hello, my remote is two wears old, model 98TR7SW-ENT-VSF, few buttons are heavy to response. Any suggestions? I can open it by myself if necessary, thanks, Neno
well open it up and see that all the buttons that were hard to respond have the black gummy worn down get a remote that does not work and cut those black circles and glue them to your remote and close it will work done it to my cars remopte key
Oct 28, 2009 | Televison & Video
Menu window opens and stays in view yet not called for it
This is a hardware issue of Monitor.
Most probable reason is defective key switches.Test switches some maybe leaky-Replace.
Please provide feedback and rate the solution.
Jul 07, 2008 | iiyama E431S-B 17" LCD Monitor
No startup
For my FTR9965, it is necessary to physically unplug the
power cord from the box before you are able to enter the service codes. The sequence is:
1. Unplug the box for a few seconds.
2. Plug it in again.
3. Turn on the box with the front panel power switch. Wait for the green light to come on.
4. From the remote, quickly enter 062596 plus the info key.
5. A message comes on the monitor warning you that you could really screw things up if you don't know what you're doing, and do you really want to continue? If yes, hit any button on the remote. You only have a few seconds to respond.
6. The "stand alone" option is near the end of the "service" menu list. When you find it, change the "no" to "yes".
7. Go back to the main SAM menu, scroll down to "Store", and hit OK. I'm assuming this makes the "yes" selection permanent.
8. Enter "00" to exit SAM.
Aug 08, 2007 | Philips E-Box FTR9965 DTV Receiver
Samsung SyncMaster 750S Monitor Logo
82 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
