Question about Zenith Z50PX2D 50 in. Plasma HDTV
POP NO PIC
What Boards Went OUT??? would it be the H , Y or Logic Board. what can I do to prevent this from Happening again??? Thanks Ron
  • BuinGuy Jan 22, 2008
    Thanks. Tech People are Coming out this Fri to Fix Should I Insist on Replacing all Boards???? C Control Board , Z Board , Y Board, Y drive Top and Y drive Bottom
  • BuinGuy Feb 23, 2008
    Thanks a Bunch Zjut.... The TV Tech Came and Fix my TV.. I must say the Pic and Sound are as Beautiful when is was New... The Tech Replaced the Y Board..which was no good.. and the TV was Working Great. But for Good Measures he also replaced the Z Board... After he was Done He explaned to me I shouldnt have this Problem with TV anymore. He Told Me that the Parts that He Replaced are Much Better than the Old Ones from the Factory.. The Ones from the Factory there Part # ended with and A.... He Said the New Boards end with a B which are Much Better... Is this Correct??? Thanks BruinGuy
    Sniper:
  • 67 Answers
I have a similar problem. The green power light blinks 6 times and on the 6th time stays ON. It looks like black is spilled on the screen. A few pixels start to show and then get progressively bigger the longer i let it stay on. The picture is also dim. I've replaced the y-drive, z-sus and control boards with no success. Any help would be appreciated
Posted on Feb 22, 2008
  • 106 Answers
Try to replace the Y board first
Posted on Jan 22, 2008
  • LX Jiang
    LX Jiang Jan 22, 2008
    Normally don't need to replace all boards, just replace the faulty board is ok.
Red noise or flicker on bottom half a plasma screen
Hi!
as i see your picture maybe that is lack of vertical sync or vertical ramp... can you send me the service manual then i diagnose this problem. send me at gmf_likha@yahoo.com
Nov 08, 2007 | Televison & Video
What is the fix for my 2003 Chevy Tahoe with the gauges not working till I pull the pic/dic fuse and then put it back in.
IS this a one time issue? IF so when the battery dies and is jump started, the voltages can be spiked or sag and this causes issues with the electronics in the boards. When you pull the fuse and put it back you are resetting it and not letting drop or sag or spikes happen. If the issue keeps happening then you need to look at for issues with bad connections on the boards or the BCM
Oct 27, 2017 | 2003 Chevrolet Tahoe
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
Power Issues with Sanyo DP50749
Main board is most likely but that is an educated guess--problem with all these is you can only check so many things and then have to guess and try a board.
Apr 22, 2012 | Sanyo DP50749 50 in. Plasma TV
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Pop sound,Sceen went blk but has sound? SamsngPlasma1yr
Check all the parts on the board that have the flashing light and those boards beside it.Look carefully,searches for those parts call capacitors,they have very common problems that have leakages of gases.Replaced these bulges up on tops,puff on tops capacitors, will cure ur tv problems.Or replaced the board that have the flashing light.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish of that board for the replacement.
Jul 07, 2010 | Samsung PS42P2S 42 in. Plasma Television
Vizio P50HDTV10A TV went pop now has a black picture
Don't know which boards Z or Y have dead capacitors pop open,take ur tv aparts check boards that have pop opens parts or burn marks on them.Replaced that board will solved ur problems.Tries Shopjimmy.com,Ebay.com to buy refurbish boards for the replacement.
Mar 22, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Vizio GLV47 LCD HD TV No Picture No Sound?!?!?!?!?
Without seeing the set and takig some measurements, I can't say for sure where the problem is, but the part info is listed below. These can be purchased through tritronicsinc.com. Please note that these boards have a "core" cost. This means that the "core" amount will be refunded to you once the defecive board is returned.
Dan
Power board: 0500-0510-0340 Cost: $102.97 Core: $10.00
Main board: 3647-0072-0150 Cost: $202.68 Core: $40.00
Apr 27, 2009 | Vizio VO47L 47 in. LCD TV
Would like a guru's assistance
They need to replace both sustain boards along with the power supply and the logic board. These are the common 4 for a LG/Zenith dead plasma that popped! Good luck.
Dec 06, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith Z50PX2D 50 in. Plasma HDTV Logo
153 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
