Hi
I have the Karcher 360M. I don't know its past history. It was working fine at the start, and still does, except now the pump pulsates periodically and annoyingly when the trigger is off. The pulsations are for a few seconds then followed by a few seconds interval. It sounds like the pump is going, but can't get the water out through the closed nozzle. This is a friends machine that I have tragically borrowed, the pressure is now on me to fix the problem before I return it.
thankyou
unfortunately these little units have this problem commonly, 9 times out of 10 it will be the plastic head or the plastic valve block on the unit will be cracked and leaking slightly... it builds up pressure then leaks out and tries to build up the pressure again and this just reoccurs over and over...
you can get this repaired but is normally about half the cost of a new unit, if the pressure is still okay i would probably recommend just keep using it until it proper dies...
If you do get this fixed, we have studied into this and believe the main cause of heads cracking is warm water say if your inlet hose is in the sun for a period of time this can cause the water to become quite hot or if the unit sits and water trapped inside the head assy freezes can also cause this.
Hope this helps
Kind Regards
Brad
Testimonial: "Thanks very much brado83. The cycling interval has now increased, so I am going to try to fix this myself.You have confirmed my part suspicions.Cheers"
