Question about Frigidaire FGF378AC Gas Kitchen Range
Oven Knob all of sudden shuts oven off at 300 degree mark not "off"
I turned the oven on and when I went to turn it off it didn't shut off at the "off" mark, after playing with it I finally got it to turn off around the "300" mark. I checked the inside of the knob and it is not cracked or slipping.
  • 1,554 Answers
The inside part that locks the shaft to the controls is loose.
it can be fixed. but will take some ingenuity.
you will have to take the control completely apart to get to the loose area, walmart has some plastic glue that comes in a 2part tube for 4.00 that can repair most plastics and provide fill a the same time.
or just order another control if you can find a place that has it.
Posted on Feb 03, 2008
If you remove the knob, you will see the very center of the male part the know attaches to has a small flat head screw in the middle of it. Buy turning this screw in and out, you are micro adjusting the temp when the oven cycles on and off. Its best to have a digital thermometer set up within the oven so you can see exactly when the oven cycles on and off. It's going to fluctuate about 20-30 degrees. So set your oven to 350, let it turn on and watch carefully when the red light shuts off it should be between within 30 degrees from where you set it, up or down. If its too low,turn in( could be out, I forgot) the screw in the center of that know with a mini flat head screw driver. If you turn it and the light goes back on, you turned it up. If it does not go on in an quarter turn, you went lower. Once your digital thermometer matches up closely whith what your oven says, your good. 25 degrees isn't much to be gentile whith turning that middle screw, you could miss your mark and be off even more very easealy.
May 16, 2014 | Thermador PRD304EG 30in Pro Grand...
My Frigidaire oven will not turn off! When I baked at 475 degrees, and pushed "Clear", the oven would not turn off. The next time I used the oven I was able to turn off but it went back on! This is he
You've shown in the video that this is an intermittant problem. These are among the most difficult to isolate because the failure is unpredictable.
This is really not something that you can deal with or fix on your own, as there are really no "user serviceable parts" inside for you to replace in this oven. You would need service manuals, test equipment, etc. to locate and replace the offending part (if it were a fuse or similar, once it blew it would fail predictably and be easy to find - this is not the case for your problem - assuming you have shut off this oven successfully in the past the way you demonstrated in the video and it sometimes does not shut off).
You will likely need to call for professional service. They are equipped with the tools and knowledge to get your oven working properly again. Good luck!
Mar 14, 2013 | Ovens
Have Whirlpool electric range super capacity 465 with accubake system oven will not shut off
Karen, We are sorry to hear about your Oven. We are happy to look into your concerns but we will need your your address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to
Jun 12, 2017 | Whirlpool 30" Self-Cleaning Freestanding...
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
I have a JennAir Model JES9860BAS and the oven don't work
Well it probably is a faulty control but before ya blow any money on an oven control check the oven sensor. If it is open or grounded to the frame then the control cannot read the voltage sent through the oven sensor and know to shut down.
Dec 26, 2009 | Jenn-Air JES9860 Electric Kitchen Range
My oven burns everything.
Use a 'oven thermometer' in the oven and determine the 'actual temperature' in the oven. Your knob setting is off (not calibrated) and the oven is hotter than the control knob setting.
Sep 16, 2009 | Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
Sep 05, 2009 | Ovens
Frigidaire FGF378AC Gas Stove
There are 2 possibilities:
1) Are there 2 knobs to control the oven? If so, they may be switched.
2) Depending on the thermostat used, it may be possible to put the knob on upside down.
Jan 22, 2008 | Frigidaire FGF378AC Gas Kitchen Range
Frigidaire FGF378AC Gas Kitchen Range Logo
127 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
