Question about Sharp Aquos LC-20B6US 20 in. LCD Television
Upper half of image only
The following happens very often when playing a DVD and sometimes also when watching certain TV stations: My SHARP AQUOS LC-20B6U suddenly just displays only the upper half of the image (in good quality). When this happens, I can get it back to normal by pushing the menu key on my remote control 2 times. Do I have to bring this Liquid Crystal Display to a repair service or can I do something myself?
Thanks in advance for your advice
Peter Muehlemann
Clermont, FL
    New Friend:
  • 44 Answers
Make sure the aspect ratio is set correctly. Also try a different dvd player and see if the same problem occurs. If the problem is fixed when you hit the menu button on the TV remote it is def a problem with the TV. The fact that it happens on Cable and DVD leads me to believe it is def a problem with the TV. Go into the menu try a few different aspect ratios like 4:3 and 16:9 when the problem occurs again. I doubt its the display if this problem is not occurring very often.
Posted on Jan 22, 2008
  • 1,894 Answers
How old is the set?
  • dewan nafees ahmed Jan 22, 2008
    i think your display is dying.....
    but there s no harm in trying to change the aspect ratio.. but i dont think it would be of much help..
    you will have to take it for repair i think
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
I have a Sharp Aquos # LC-45GD4U. It now suddenly turns off by itself and stays off until I turn it back on. This happens while watching live TV or playing back a recorded show. Ideas?
Check the ventilation fins on the back. Sometimes they get obstructed with dust and then heat builds up. The TV then shuts down to protect itself from overheating. You can use a blow dryer to blow it out.
Feb 01, 2013 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Samsung HT-X70 DVD player
i have this system set up to a sony bravia kdl40v2500 tv and sometimes when playing a dvd the screen will go blank and in the corner 1080i will show. I do not know how to change the resolution and does this need to be done on dvd player or tv. Can you help me.
Feb 20, 2008 | Cell Phones
Aquos Turns off by itself
no. It goes black, then about 5-10 seconds, it turns itself back on.
Jan 01, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
There isnt really anything you can do to fix it yourself, you can order the part over EBay, not hard to install just unscrew/unplug --- plug/screw..
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-20B6US 20 in. LCD Television Logo
125 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
