Question about Dell Wireless 2350 Router
Windows Vista and Dell Wireless 2350
I'm running windows vista, when i check out the list of wireless routers i see my router (dell wireless 2350) at full strength. I am able to connect, but when i'm connected i have limited internet access... 2 bars of "strength" and it keeps disconnecting/reconnecting... Help!
  • Nickers_24 Jan 22, 2008
    By the way, everyone else is able to connect at full strength... if that help any.. :S
  • Anonymous Mar 17, 2008
    same problem here i've narrowed it down on my pc to at least one program that knocks the router out of commission -- yahoo im -- it seems crazy but when i open that bad boy up i have to turn off and on my router to get wireless connectivity back
    Problem Solver:
  • 11 Answers
Try updating the driver for your wireless adapter.
Posted on May 01, 2008
  • daveohr May 01, 2008
    On a side note...I use Digsby as my messenger app. It works great and you can integrate it with multiple messenger apps. and facebook. I had a user that was having issues with Yahoo Messenger locking up her PC and since switching to Digsby it hasn't been a problem.
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
Since upgrading WRT150n router firmware, to be
Have you had a look on the firewall website for a suitable firewall system that compliments windows 7?
I had to download a new one myself when I went from Windows XP to Windows Vista.
Sometimes changing systems means you should also change your firewall, then you'll have the most up-to-date software going. Plus it won't slow your computer down like it doesn't sometimes.
Hope I helped Dr Reed
Apr 15, 2010 | Linksys Wireless-N WRT150N Router
Nintendo's support page doesn't list Dell routers
You will need to check the wireless settings of the
router
is there any computer connected to the router ?
If yes then you can open the router set up page on
that computer.
Router set up page is the page where you can check
all the wireless settings of the router.
once you get the wireless settings of the router, you can try to connect to the wireless network.
Click here for step by step instructions
Jan 23, 2010 | Dell Wireless 2350 Router
Vista hook up with dell wireless 2350??
You really don't need the setup disc to setup a router of any kind. First you need to plug the computer into the router via ethernet cable. Jack into one of the numbered ports on the back of the router. Once Vista receives an IP address, click start then type cmd and press enter (this opens a command prompt). Type ipconfig and note your default gateway. This is the IP address you will need to type in to Internet Explorer. After sucessfuly doing that it's probably going to ask you for some login credentials. Check your user manual for the user name and password. After logging in, set your router up as needed.
May 23, 2009 | Dell Wireless 2350 Router
Wireless router won't go wireless
On the front edge of the laptop, 3rd button from the left is the radio on/off button.
Mar 18, 2009 | Linksys Wireless-N WRT150N Router
Can't connect to certain https sites.
check windows firewall also install https certificates.u can see i lock in right corner of internet explorer.when acces this site.
also check firewall settings in rotuer and allow https prot 443 in allow list.
Jan 05, 2009 | Dell Wireless 2350 Router
Disconnection problems
I see. You can try changing the wireless settings of the router. You can do that by accessing the web based utility of the router. Here are the instructions:
1. Click the Start button, and then click Run.
2. Type the following text in the Open box: http://my.router
3. If this is the first time configuring your Dell Wireless 2350 Broadband Router, or if the user name and password have not been changed from the default settings, type admin in the User Name field and admin in the Password field.
4. Click the OK button. The Configuration screen appears.
5. Under the Basic settings, under Wireless Settings change the channel from Auto to 1, 6, or 11.
If that does not work, you can try updating the firmware of the router. You can download the firmware from this site:
http://www.dell-drivers.com/dell-drivers-downloads/Dell-Wireless-2350-Broadband-Router_8689.shtml
Here are the instructions on how to upgrade:
1. Reaccess the configuration page of the router using a wired computer.
2. Click on System Tools, find Firmware Upgrade.
3. Click Browse and search for the firmware you downloaded from the site I gave you earlier. Select it and then start the upgrade. Let the firmware finish its upgrade.
May 21, 2008 | Dell Wireless 2350 Router
Cannot connect to internet through router
there might be a wireless setting that is not yet set properly on your son's laptop. If there is a wireless security enabled on your dell router, you have to enter that so that the laptop will connect. Also, if you are using Windows xp or vista, you can try to remove the preferred networks first before reconnecting.
If the same problem occurs, you can try changing the channel on your router and make sure that the SSID set is personalized. If this still does not help, you can try bringing your son's laptop to a hotspot to check if it can connect. If it doesn't then the problem is on the wireless adapter of the laptop, you can try to update the drivers for that one.
If you encounter any problems, just click on the ask me button and I'll help you with your concern as soon as I can.
May 06, 2008 | Dell Wireless 2350 Router
Wireless device disappeared with Windows Vista installation
Unfortunately, you have mentioned the router, which is no longer supported on the Dell site, but not the network card you are trying to use, please advise so as we can try for a driver. I assume you have tried installing the XP driver, as sometimes this may or may not work.
Mar 16, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Dell Wireless 2350 Router Logo
136 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
