Question about iLO LCT32HA36 Television
My ilo has the built in atsc tuner
When i plug in the coax cable from wall into ant 1 (DTV) all i get is a blank screen with "no signal status"
  • Anonymous Jan 23, 2008
    Same exact problem here but I have a 26"
    One of my roommates has a 36" LG and his DTV works perfectly...
  • 3 Answers
Try plugging in a powered antenna.
The DTV coax input is for over-the-air HDTV transmissions which vary depending on your location and surrounding buildings.  I have the LCT32HA36 hooked up to a powered antenna and it works fine, but it wouldn't work when I plugged in the cable from the wall.
Posted on Jan 27, 2008
How can i tell if my tv is digital
The iLo IWT3206 TV provides two built-in -- or integrated -- TV tuners: a National Television System Committee (NTSC) tuner and an Advanced Television Systems Committee (ATSC) tuner.
While the NTSC tuner allows iLo IWT3206-viewers to receive analog, free-to-air TV broadcasts, the ATSC tuner allows viewers to receive digital TV broadcasts via a cable or satellite provider.
The benefit of having an integrated ATSC tuner is that it negates the need for a separate cable box or satellite receiver, which can take up space.
Oct 24, 2013 | iLO IWT3206 TV
How do I connect it to my cable? I have a co-axial line (I think) and there is no visible port to plug into!
The ILO 2600 does NOT have an ATSC tuner for the current digital broadcasting.
Note that a slightly later version *might* have come with such.
Later models equipped with it usually have TWO coaxial inputs on the back whereas the original one only has the now obsolete NTSC coaxial input.
There are several possible explanations of what your friend has told you: he may have had a different model or he may have connected it to a cable which was broadcasting in the older analog format already. Or he simply had a different TV with a built-in tuner that can pick the signal.
So first thing I'd check is the number of antenna inputs you have on the back. When there are two the second is usually labelled "DTV".
Second, is there a Comcast cable box somewhere on your end? And if yes then isn't there other outputs to it other than the coaxial cable?
Finally, it is possible to find a digital-to-analog converter on Internet and eBay in particular, but I wouldn't rush doing that. It's practically half the price of a new 32'' LCD TV and you wouldn't be quite happy with the quality anyway.
Nov 28, 2011 | iLO 2600 Television
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
I have a Jensen TV, Model Number TS2050J. I need to know if it has a QAM tuner built in.
Hi.
No, your tv is an older model sdtv with an analog only NTSC tuner.
Newer model have an ATSC/Qam digital tuner, but not your model.
This means that if you want to watch tv, you'll have to get a converter box. It will have the ATSC/QAM tuner i it, and it converts the signal into lower definition NTSC, and then sends it to the tv through either coax cable, or rca cables.
Once in a great while you might even find one that has s-video output, but those usually are expensive.
I hope this helps you out.
Feb 08, 2011 | Jensen TS2050J 20" TV
I am not using cable or dish...what type of antenna should i use to get the most out of the digital conversion...and is the built in converter adequate or do i need converter box?
The specs for this TV shows it has ASTC and NTSC so you do not need a converter box.
Almost all the Digital channels are broadcasted in the UHF band.
When you scan in the channels the VHF numbers will still show but the actually signal will be in the UHF band.
Go to
WWW.TVFOOL.COM and enter your ZIPCODE to get the stations in your area.
MPN: IWT3206 Key Features Digital TV Standard: SDTV Diagonal Screen Size: 32 inch Display Capabilities Built-in Tuner: ATSC · NTSC Image Quality Comb Filter: 3DYC / 3D Digital Audio Features Audio Type: Stereo SAP / MTS Stereo: SAP / MTS Stereo Technical Features Sleep Timer: With Sleep Timer Connectors Rear Input Connectors: Composite x 1 · Audio (RCA) x 1 Front Input Connectors: Composite x 1 · Audio (RCA) x 1 Screen Text OSD Languages: English · French · Spanish Miscellaneous Product ID: 37594421 More Information Details: Big picture, small price. Enjoy watching your favorite, sports, programs and movies on this generously-sized 32" TV from ilo. The side stereo speakers help create a richer sound experience. Even more conveniently, the built-in digital (ATSC) tuner accesses digital content without the need for a separate set top box that takes up space. And since the screen delivers standard definition (SD) resolution.
Apr 05, 2009 | iLO IWT3206 TV
Can I receive a digital signal and if so, how?
I'm pretty sure this TV already has an NTSC/ATSC/QAM tuner in there, and should need no converter box whatsover... I say this because I own one...
Mar 09, 2009 | Insignia NS-27 TV TV
No HD
the digital tuner needs to be checked for soldering connections and if that don't fix it then you will need to get a new digital tuner.put in. but you can unplug the tv from the wall plug for a little while and that may help but if not then it will need to be checked for bad soldering or it will need to be replaced
Oct 18, 2008 | Protron PLTV-32 Television
How do i convert my dtv-5801 to the new free digital air waves
My information indicates that the DTV-5801 has a NTSC (analog TV) tuner built in bot not and ATSC (digital tuner). It does have HDTV inputs to which an external tuner can be connected. For Off-Air Digital TV, add an HDTV (ATSC High Definition tunner) and you are set to go. Do not buy the DTV converters, they have down converters built in and only deliver SD to the outputs.
May 26, 2008 | Runco DTV-5801 58 in. Rear Projection...
Misubishi warrior 2 intermitant pic freezes 1 second or less
Hello frogman,
The freezing of the picture denotes a loss of signal on a digital (Having a ATSC tuner) TV. If your TV is not digital (Having a ATSC tuner) then it is the device that you have connected to the TV (Cable Set-top Box, DTV Tuner, etc). In the likelihood that it is your TV I would suggest getting a better antenna first if that does not fix the problem you may have a tuner problem. However lets not look at it that way first. What we need to do is to determine if it is the TV of whatever you have connected to the TV.
First unhook the connection you have from the cable to your F connector of the TV (you should see snow or a blank screen) connect a antenna to the F connector of the TV, do you see a snowy picture or a clear sharp picture (snowy= NTSC tuner, clear-sharp= ATSC tuner). If the tuner is NTSC then check you cable device and the connection between your TV and the device and the cabling between the device and the wall. If the Tuner is ATSC then you will have to check all of your connections, and finally if the tuner is bad it has to be replaced by a qualified Tv repair shop.
I hope this helps,
Thank you,
Shuttle83
May 09, 2008 | Televison & Video
iLO LCT32HA36 Television Logo
205 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
