Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Why can unit handle DVD+R 16x?
Why recording from LINE IN 1 S-Video using DYNEX DVD+R 16x does not record clean(garble video, frequent pausing)? I tried with DVD+R 4x and ok. I though this unit handles higher speed. Would not play other 16x disk finalized for other recorders.
What should I go with? 8x? DVD-R? different brand DVD+R maker?
Or could it be a bad unit. I did buy at bestbuy as an open box item.
  • smizguy Feb 13, 2008
    Thank you. I went with Verbatim and it works much better.
    Scholar:
  • 84 Answers
OK, in a nut shell, and with out knowing the full set up you are using here is what basicly happens as you record your DVD, the system reads the information into a cache.. it holds it there untill the burner cathes yp to it then it asks for more information to be place into cache. Cache is one of the things that make a good brand of DVDR/RW expensive and the lack of it is why products like Dynex are not.
One thing you can do to maximize your record speed is not to use cheapie type disks. Bite thte bullet and by good quality DVD disks to use for recording. Also, try to not tax your system by running anything through it or with it while it's recording.
Other wise... you will have to live with a slower recrding rate unless better media helps out but it would have to help you out a lot.
Posted on Feb 13, 2008
When trying to record a home video VHS to DVD this is what I get. E-4 54040990 Cannot record on this disc. The disc is brand new.
Have you've tried cleaning the laser with a cleaning disc?
Failing this it may be worth removing the cover and cleaning the lens directly with a QTip and some lens cleaning fluid. Only use a drop and then wipe off with a clean dry QTip.
The other option is that you are using an incompatible format of blank DVDs. I've heard of people having problems using DVD-R & DVD-RW and although it is lised as being suitable for all types of recordable DVDs I belive you're best using DVD+R & DVD+RW.
The Manual states
Recordable disc
• We strongly recommend for good recording quality:
SONY DVD+RW 4x, MAXELL DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, TDK DVD+R 4x/8x/16x,
MAXELL DVD-RW 4x, MAXELL DVD-R 8x/16x
• Discs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+RW 4x VERBATIM DVD+R 8x
VERBATIM DVD-RW x VERBATIM DVD-R 8x JVC DVD-RW 4x MAXELL DVD-R 16x
May 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Using a JVC /DVD/S-vhs dual dubbing Deck model jvc sr-mv55u Trying to do a straight dub from an edited S-VHS tape to a formated for video DVD for archival library. I am following the instructions in the...
now days dvd player comes with advace tacnoloy
u not need make vedio dvd u make to your dvd as a data dvd & dvd plyer read it isely so dont need to do vhs or vcd
Mar 29, 2008 | Televison & Video
I have an LG Model: RC897T. Video: the picture records fine but the audio is garbled and scratchy. How can I fix?
If you have some alcohol and swabs...good long ones other wise take cover off and clean the audio head which is just to the side of the video head. Might as well clean that one too. Do not use any abrasives though.
Nov 02, 2010 | LG RC897T DVD Recorder/VCR Combo
Cannot record on 16X DVD-R
You will need to call Funai 1 800 605 8457 give them your brand / model number and expose your problem - they should be able to send you an upgrade disc but it will cost you -
If you want my advice - you DO NOT need a 16x disc inside a DVD recorder - the optical drives used on DVD recorders and even worse a Funai drive are quite bad as it is in terms of writing strats for higher speeds - you are better off recording at 8x on a 16x disc.this will provide better burns ( lower PIE/PIF errors and jitter %).
Aug 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Emerson EWR 20V5
Jan 17, 2009
I posted this Jan 3, 2009 and seem to have a solution.
Similar problem. E4 54037380 Can not record on this disc. Even though it is from the same package of DVD-Rs that I have successfully recorded to previously. Contacted them about 9 months ago without a successful resolution so I am trying again. Unit will play any DVDs, will record and play back DVD-RWs but will not record on my imation DVD-Rs 8X discs that worked fine in the past. Starts to record for a few seconds and then the error message appears (sometimes with slightly different final 4 digits of error number). Other postings have suggested: maybe a firmware update is available (I requested and we will see Emerson's response), trying slower speed discs (I am skeptical since these 8x imation discs in this same package previously worked, and the instructions say 1-16x for DVD-Rs), unplugging the unit for 1/2 hour to reset the unit (did not work), playing the last disc recorded to the end and then trying a new disc (now it recorded for about 30 seconds rather than 10 seconds but then got E4 54043E02 error message, different but still did not work). So I am hoping for something more productive out of Emerson this time.
Update Jan 17,2009. Bought a CD and DVD cleaner disc with the little brushes on it. Cleaned the EWR20V5 per the cleaner instructions and tried to recod on the imation DVD-R 8X that I had used successfully in the past, no luck, same error message. So I bought another brand, maxell DVD-R 4.7GB up to 16X and IT WORKED. The instructions on pg 25 say for DVD-R "up to 16X" may be used but "4X-8X disc is recommended". Go figure, no idea why the 16X worked but they did in this case. So just a suggestion to try other brands. Someone else had suggested that also so I gave it a shot. $8 of new discs and $13 for the cleaner and I've back in business.
Jan 16, 2009 | Emerson EWR20V4 DVD Recorder/VCR
FIRMWARE UPGRADE
FYI, I did the 8x upgrade and the unit became flakier. So one time it handled 8x discs and the next no. So it went from very stable to hit or miss. Redid the update and the same problem.
2x RW discs work ok in it and can be read, edited, and formatted in my newer recorder that handles 16x discs.
Jan 01, 2009 | Symphonic SR90VE
Using up to 16x disks
This units DVD drive is only able to spin at a max of 8x on DVD-Rs and max of 2x on DVD-RWs. Also, this unit is a - only recorder. This means if it is a +, it's not going to work.
Since the unit is a DVD-R 4x max recorder, the unit will need to have it's firmware upgraded. This will only help to record to a DVD-R 8x. You can purchase this upgrade with the manufacture of the unit. Call the 1-800 number listed in your manual and press 3. They will walk you thru the steps to find out which upgrade is needed.
Apr 04, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Emmerson DVD/VCR EWR20V5
if yoy dont hav firm ware up date you cant fix the machine. the machine if working will on work on 4x. like i said if the machine is not working you maybe able to fix it with the firm ware up date that lets it record on 8x only, now if some of the people out ther has the firm wade update disk, they could shareit with all the people who dont, i had one but its been 2 years sence i used it, i will look for it and make it available for all
Jan 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
