Question about Jwin JV-TV1010 5.5 in. Portable Television
Horizontal white line
Tuner and receiver seem to work ok. Using the tv option all I see is a horizontal white line. I can hear audio OK. Seems there's a problem with the vertical . Do not have any schematics. any particular component failure that causes this?
Help!
  • ossalater Jan 22, 2008
    Hi slinteriors;
    The only transistor i can locate on a heat sink is v409. On it is marked MX 2SB834.
    I cannot locate any data sheets or equivalent on the web.
    Can you help.
    Alternatively close to the v-size variable resistor is a 10 pin inline ic marked CD1031CS. (also attached to a heat sink).
    Any ideas?
    regards.
    ossalater
  • 8,617 Answers
Verticle output transistor. It will be mounted to a heat sink. t should have Verticle stamped on the circuit somewhere near the Transistor. Locate the numbers on tht Tansistor and let me know what numbers and letters are, and i will post a link to where you can buy a replacement.
Posted on Jan 22, 2008
Loss treble using THX mode with BOSE acoustic mass speaker
What you are hearing is a combination of the programmed signal processing and equalization of THX mode plus performance limitations of the speakers.
Your only options would be to be either change your listening positions or the positions of the speakers, so that there is a direct and unobstructed line that is on axis from your ears to the speaker drivers. Or, you can disable THX mode.
Jan 03, 2012 | Onkyo TX-SR703 Receiver
Yamaha RX V992, HDMI 2 mode
tell toshiba dvd 720 p only and use bitstream outsetting in audio of dvd player ok if that dont do it run dvd directto tv then digita opti cable from tv back to sterio ok
Jan 21, 2008 | Yamaha RX-V992
Using only Stero speakers. Sound only from right speaker. Left not working. However if I select tuner (not tuned in) the speaker works. Diconnected wires numerous times. Any help would be...
Hello
Check its audio settings. If the 'balance' control is at its one extreme, one speaker of that side son't work. When you select 'tuner' the the set sutomatically goes to 'Mono' [according to selection]; and both speaker will work. Check if stereo option is activated in its audio option first. If not, select it to stereo, dolby digital or so what you want ot hear. If all selections are OK, and still the problem perists, its digital processing section should be troubleshooted. Actually this is not a user repairable option. Contact any experienced service personel or Panasonic Authorised Service Center at your town. OK.
Jun 29, 2011 | Panasonic SA-HE70 Receiver
Need to locate the pincushion circuit on RCA F32632SB 32" TV
ok this might help rca labels their circuits this way..
0000 tuner
1000 the tv processor
1100 remote receiver
1200 audio IF
1400 a/v hifi outputs
1500 s-video inputs
1700 stereo audio demodulator
1900 audio output
2300 video IF
2400 sync separator
2700 luminance processor
2900 rgb bias and drive
3100 system control
3300 analog interface
3400 front panel assembly
3600 tuner control
4000 ac input
4100 b+ regulator
4200 degauss
4300 horizontal osc.
4400 horizontal output
4500 vert deflection
4600 standby regulator
4700 secondary power supplies
4800 pincushion correction
4900 x-ray protection
5000 kine driver
7500 fm radio
Jan 15, 2009 | RCA F32632SB 32" TV
Tuner not working - denon AVR 3805
turn left hand knob to select tuner (round knob on top left front side)
Dec 31, 2008 | Denon AVR-3805 Receiver
No Picture but have sound
OK I got my first TV, first to repair myself that is, and I have no training at all but am kind of a tech dork wannabe. So I checked and I have sound but no signal through the TV tuner, so I hooked up my Zenith VCR to aux 1 and sound with signal appeared, the VCR tuner still works :) so I am leaning toward the TV tuner. It is visibly damaged, and I'm hoping it is as simple as a broken connection. I also noticed a vertical flash and pattern of horizontal lines when it is turned off (white). sooooo I push on.... help!!!!!!!!!!!!! :>}
May 02, 2008 | Televison & Video
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
Jwin JV-TV1010 5.5 in. Portable Television Logo
551 people viewed this question
Top Jwin Televison & Video Experts
Jaime Hernandez
William
romy sibug
romy sibug
Are you a Jwin Televison and Video Expert? Answer questions, earn points and help others
