JVC TV WHITE SCREEN WITH HORIZONTAL HUM BAR AT THE RIGHT SIDE OF THE SCREEN
It sounds like a fault with the power supply bus feeding the video processing circuit.
It probably wont cost to much to get fixed, however make sure you get a quote on labour and parts.It may be and end of line model and parts could be quite expensive to get hold of.
Also if possible find a regisered repair man in your area, usually you can do this by ringing up JVC themselves as they often keep details on file.
Just make sure you asses wether it would be cheaper to just buy another tv, or to go ahead with the repair.
Let me know if this helped.
Posted on Jan 22, 2008
Last night I turned my Polaroid TLX 04244B off, and had zero problems. This afternoon, I have a 6" pattern of horizontal lines across the right hemisphere of the screen. They come and go, darker...
You are probably seeing hum bars which may be due to an AC ground loop that is going through the shields of one or more of the cables inteconnecting the TV with one or more of the other video components. You should do the following to try to resolve it...
1. reseat all the interconnecting cables between TV and other units
2. have all AC power supplied by one power bar with a ground plug
Mar 17, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
Rolling Bars
This sounds like 60hz Hum Bar caused by a Ground Loop. Something is not grounded like the Component Cables you might be using or your Cable box is bad. That is a common problem with cable boxes.
Apr 13, 2010 | Samsung HPN4239 42 in. Plasma HDTV
Jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Nov 30, 2008 | JVC AV-27230 27" TV
Horizontal ines---original post got wiped. Sorry.
leaky cap(s) in vertical circuit. shouldn't be more than $125 (plus taxes) parts and labour
May 14, 2008 | JVC AV-27230 27" TV
3 INCHES HORIZONTAL LINES ON SCREEN
i have a whie line going horizontal all the way across the sceen. how do i get rid of it?
Apr 29, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Purple and Green hum bars?
You could have a drain on your AC (120) causing the hum bars in your set . Best thing to try is to reduce what you have plugged into your 120v outlet . One of your unit could have a capacitor going bad in its power supply causing the hum bars . Even if it is not turned on. Try one unit at a time . if you find out it one of your units they make what is called a line conditioner which filters out these hum bars . Good luck
Jan 30, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
start>control panel>display>settings>advanced>monitor
then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
