Question about Pioneer SD-533HD5 53" Rear Projection HDTV
RED LED IS ON BUT GREEN SHUTS OFF
I WAS TOLD TO REPLACE THE FUSE ,BUT WHERE IS THE FUSE LOCATED?
  • RAY FINKLE Jan 22, 2008
    WHEN I PRESS THE POWER SUPPLY ON THE RED LED IS LIT UP,WHEN I PRESS THE SMALLER POWER BUTTON THE GREEN COMES ON FOR A SECOND THEN TURNS BACK TO RED...NO BLINKING
  • RAY FINKLE Jan 23, 2008
    i can handle a fuse but the rest I will have to let the pro handle. If u could talk me through it let me know and I will give u my #. Thanks
  • Pioneer Master
  • 8,617 Answers
The fuse is on the power supplu board, but dont think thats your problem. Is the setompletely dead when you try to power it up? Does the LED light blink? If so how many times does it blin before it pauses for a second.
Posted on Jan 22, 2008
  • Sonny Berry
    Sonny Berry Jan 22, 2008
    The red light mean your standby voltage i ok.I would check Q309 and Q324 for a short between C & E collector and emitter that can stop horizontal deflection which will shut the set down. Also check Diode D2224 for being shorted this will trip the ray protection circuit and also shut the set down,. Let me know if you need me to clarify anything.
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    You would need a service manual then with some support explaining how to test various parts you would probably be able to handle it, but you wold need a manual just to have an idea on where to locate the components and se what voltages are required at the test points.If you want to give it a try let me know I can post a link where you can purchase the service manual and they will email it to you. Hope this helps.
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
We have a Samsung HL67A510 and when I turn it on, I can hear a click and the green LED light blinks and the "on" music plays and I can hear the fan blowing in the back. But after a couple of...
Hi Isnovero,
The main reasons of your problem is the bulb which is already came to its end. The unit will automatically shuts off when it sense a bulb failure. But before you replace the bulb I would advice you to work first on its power supply. Look for open fuse/fusible resistor and spot some bad solder joints. This will do the same symptoms like what it showing now. If you don't have necessary tools and test instruments, and can't do the job yourself, I would advice you to look for a professional to troubleshoot the problem. Don't attempt to work in the power supply if you don't know the safety precaution of handling it, there some stored electricity enough to hurt you with a little mistake only.
Hope I helped you.
Have a nice day! Thanks for using Fixya.
Feb 17, 2011 | Televison & Video
Tv won't turn on
yes but you have to open the tv
Mar 01, 2009 | Loewe Aconda ACO9303 30" TV
I have an Oster wine cellar. the fan stopped working could it be a fuse and how do I replace it?
Do not bother trying to contact the company which made the unit they are being indigted on fraud. The good thing is that there is a simple solution to your problems. Replace the small fuse under the electric shrink wrap. This fuse is located near the red and green led lights on the electronic panel in the back of the unit. Replace with a 6.3 or 7 amp 250 volt fuse 3 x20mm , which can be found at Radio Shack. You will need to know how to solder in order to replace. All total cost to replace the fuse is about $3.00 and a half an hours time. The unit works great now, I paid another $3.00 to put in an inline fuse holder for the future when this fuse blows, if it does.
May 21, 2008 | Refrigerators
Where is the thermal fuse located and how can I replace it on a Sony Grand Wega model KDFE55A20?
It's actually pretty simple to replace.
Go to
http://www.agoraquest.com/viewtopic.php?topic=31806&forum=70
and request the troubleshooting package. It has step by step on how to replace the thermal fuse and where to get the parts.
No power RED Standby LED flashes 6 times/KDF55XS955, KDF60XS955, KDFE55A20, KDFE60A20
Mar 27, 2008 | Televison & Video
Help with kogi F9AH screen
Intermittently displays bright red/green/blue raster then shuts down with led flashing 2, 4 or 5 times
Amazingly this was due to the CRT being faulty !
Blank raster
Replace defective TDA6111Q for Red, Blue and green
Red or Green or Blue screen
Check and replace on crt module : D702, D703, D704 (all 1N4148) replace with type 1N4948T
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Nov 23, 2007 | GVision F9AH-TG Television
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Sony proj tv,sound,green pict few seconds then shuts down
could be three different things.
1. could be the crt itself as a tube with dfective phosphure wil do this
2. could be the vertical ic on the crt board
3. could be the focus pac.  located in front of tv with 6 adjustment knobs on it.
Oct 06, 2007 | Sony KP-41T65 41" Rear Projection...
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
52 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
