Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Garage door I have a sears craftsman garage door opener. the best way I can explain it is that when I press the wall mounted open/close device(button) it makes a humming or buzzing sound. The door does not move. I looked for a reset button but no luck. I 'lined" up the eyes but no luck there either. Any suggesstions. thanks Lou
  • 2 more comments
  • Tammy65 Jan 25, 2008
    thanks. I tried that and the door opens easily. Could it be a capacitor?
  • Zeke6185 Jan 31, 2008
    same problem, but the green light indicator on the ceiling mounted unit keeps flashing. I can't get an owner's manual online to see what that means. Any advice is welcome.
  • marisfixit Feb 05, 2008
    I am having a similar problem. I think the code got erased. How do I reset the code? Anyone know.
  • Ricardo1704 Feb 11, 2008
    Took opener down to replace sprocket and gear, and when I reinstalled unit all I get is humming noise from motor. Any ideas?
Disconnect the door from the opener and manually lift to see if it is binding.
Posted on Jan 24, 2008
Can open with remote, or wall-mounted button, but cannot use remote to close, and have to hold wall button down continuously (unit blinks when button is pressed and released, and stops closing until button...
If the main light is flashing 10 times when the door reverses you have a door sensor problem. Make sure they are pointed at each other and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get the small lights to both come on you have bad sensors.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Wall mount button LED is flashing, remotes won't work, door won't close unless the wall mount button is held down until the door is fully closed
Sounds like you have a couple problems. First of all press and hold the button on the wall control that has a lock icon for 3 seconds and release. This should take care of the flashing LED and the remotes will now work. Having to hold the button on the wall control until the door is closed is usually a problem with the door sensors. Make sure they are pointed at one another and the small light on each is lit and not flickering.
Nov 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will not open close with remote
Press and hold for 3 seconds the button on the wall control with the lock icon.
Aug 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont work with remote
If the small light in your wall control is blinking it is in the lock mode. Press and hold for 3 seconds the button with the icon of a lock. This will toggle the lock function off.
Aug 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
One of the buttons has a lock icon. Hold that button in for 3 seconds.
May 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door opener will not opern
2 flashes indicate safety eye issue. Check you wiring and make sure it is wired correctly and check to make sure the eyes are properly aligned.
Jan 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman Garage Door Premium Control Console Failure in Cold Weather
first guy has the mounting screws tp tight or the wire is preventing wall station for sitting flush against wall....second guy check your safety eyes...
Jan 23, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
250 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
