Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony Wega LCD Projection TV
I have an antenna to pick up local channels in HD. I have it connected to another HD TV and I get all the channels just fine. But I can take the same cable and connect it to my antenna jack on the Sony and I do not get all the channels. I get the analog ones but only one HD channel. Is this something to do with my tuner?
  • denverx54 Jan 22, 2008
    The TV is only 3 years old.
    Problem Solver:
  • 13 Answers
Yes out dated tele
Posted on Jan 22, 2008
Step by Step instructions on How to run set up for my RCA flat panel antenna to pick up local tv channels
connect your antena first then go to setup on the tv and selct channel search it will scan and find all the channels that you can pick up with your antenna
Aug 25, 2014 | RCA Digital Flat Panel Antenna
KDF-60XS955 digital anntenna connection
look for a coax cable connection on the back of your tv, connect antenna to booster, booster to tv, then in the set-up menu of tv, go to channel set-up, scan for channels
Apr 20, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Will not pick up a local channel
I have the same problem. Changing the antenna connection may help as will changing antennas/antenna position. Try to do a channel search in good weather.
Jan 04, 2013 | Televison & Video
MMy Vizio 32" tv only gets 16 channels
If your Vizio TV has a built-in HD converter, 16 channels is what you can expect. If the channels are identified with decimals such as 10.1, 10.2, etc. they are HD. The cable connection you refer to must be connected to an antenna, otherwise you would have a cable box and a monthly bill from some cable company
Dec 04, 2012 | Vizio E322VL 32 in. LCD TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
My sony wega 55'' tv screen goes blank including the sound and then comes back on a minute later. When the tv is first turned on the green light blinks 11 times
same thing is happening to me.....i chatted with a sony "expert" on sony's website he told me to use different inputs for the sources, im like listen pal, this is happening on hd channels also, where else can i plug the antenna? no response from the expert lol, but im still looking for an answer
Dec 23, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
How to set SONY TV # KLV-S32A10 to receive HDTV channels?
the new lcd tv you have will pick up hd channels. run the autoprogramming for the channels for sd and hd. be prepared for about a 20 minute wait
Jan 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
NO HDTV
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Nov 15, 2008 | Toshiba 57H94 57" Rear Projection HDTV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
260 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
