Question about SanDisk Sansa E280 MP3 Player
Need Play All option on Playlists
I have not had many problems yet (knock on wood) with the exception of reinstalling and upgrading Windows Media Player. I got my playlists transferred, but there must be some way to play all the songs on a list. I don't see a Play All option.....
  • 33 Answers
Sorry but if you are wondering how to reformat it is easy
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downl...
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Feb 10, 2008
6ya staff
SOURCE:
How do I get it to play Windows Media Playlists
Hi there
The ability to play a Windows Media Playlist, will depend upon the play software built into the mP3 player. If the software does not recognise the playlist file type then it will not play the list. Equally, the Windows Media Player list will remember the locations of the files on your computer, ie drive letter, folder, subfolder etc.In fact the whole file tree to each media file. This is unlikely to be the same on the mp3 player, and even if the player will recognise the playlist file format it probably won't be able to find the files as they won't be in the same location as the playlist is pointing to.
I suggest that you prepare separate playlists for the mp3 player.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Feb 27, 2015 | Audio Players & Recorders
Windows media player won't play DVDs
this problem is due to the decoder is missing in media player. you can download and install decoder from here
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx#DVDDecoder
just install it and play the DVD in WMP.
Question : Is your laptop is DELL???
Sep 03, 2009 | Microsoft Windows XP Professional
Playlists
you can add it by connecting your device to the pc, open either real player or windows media player and there is an option in both the softwares to synchronize the device to pc. after synchronizing, add them to your device. the playlists you created in your pc will be exactly in your device then
Aug 29, 2009 | Philips GoGear SA5285/37 Digital Media...
Playlists
What you need to do is to uinstall the device completely from the computer..once you have the device remove, open your windows media player click on tools, options, go under privacy,clear the history and caches...and then reinstall the device back...let me know if that doesnt help yo
Please rate accordingly
Thank you
Computerrrep
Nov 07, 2008 | SanDisk Sansa E280 MP3 Player
Philips GoGear SA3245 - Playlists Not Showing Up on Player
Have solved this problem on GoGear syncing with WMP 11 by going to options on the device itself, then go to the "settings" option, scroll down to "PC Connection Preferences", from here you will select the check box saying "MTP" then back out of options and connect your device and go back to your WMP 11 and drag your playlists to the syncing area and resync your device. You should then be able to see your playlists under the playlist option in music along with the "playlist on the go" playlist.
Hope this will help!
- Jared
Determan Technology LLC
Aug 31, 2008 | Philips GoGear SA3245/37 Digital Media...
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Playlist
Not possible on this model - you only have the Playlist On the Go option
Jul 23, 2008 | Philips GoGear Flash MP3 Player
Big problem with play lists
According to the manual for most GoGear's, you have to have automatic synchronization enabled in Windows Media Player for the playlists to transfer correctly.I still have not been able to verify if this is true, since I have been able to transfer playlists fine with and without auto-sync engaged.
I haven't tried a 3115 specifically, but with an SA4111 and an SA5125, I just created the playlist in Windows Media Player 11, right clicked on the playlist name after it was created, selected "Add to Sync List," and then "Start Sync" with GoGear connected. I used this method, because it seemed more likely to add the songs AS A PLAYLIST rather than just dragging and dropping the tracks WITHIN the playlist.
As I look more closely at the documentation for the SA3115, however, it does not have the same playlists options as other GoGear's - it seems to limit you to Playlist-on-the-Go. I know that the GoGear will not recognize folders that you create in Windows Explorer, so that option is out. You can connect the GoGear, and see if a Playlists folder appears in the left-hand pane underneath the icon of the GoGear in the Sync tab. My gut feeling, however, is that this player is just not as equipped as other GoGear models for playlist transfer. I'll go back to the lab on tuesday and see if I can find anything new.
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA178 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Puting playlists on my sansa
You have to set the playlists to auto-sync with the device. That is the only way they work with WMP 10. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
29 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
