Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Ws-65513 65 inch
The colors are off.what should be blue is green
  • Anonymous Feb 26, 2008
    the color is off
Check your component cables.
Posted on Jan 29, 2008
What I am trying to hook up is a Wii console using component cable but get black and white image on a Mitsubishi WS-65313 65 inch Television?
Follow the color code green for green, red for red, blue for blue, ignore the yellow wire, also be aware that there is an audio cable that is red also that wire goes into the Right channel audio and the white wire goes to the Left channel audio
May 26, 2014 | Mitsubishi WS-65313 65" Rear Projection...
JVC Hd56fn97 56-inch 1080p Hdila Rear Projection Tv with all blue color green
Talk to JVC as I have suggested and this is likely a known problem: loss of any color, picture upside down etc requires a upgrade to correct and I have seen about twenty sets with their name like this with this kind of problem.
Dec 11, 2012 | JVC Hd56fn97 56-inch 1080p Hdila Rear...
Ws-65611 color shadows
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Aug 21, 2012 | Mitsubishi WS-65611 65" Rear Projection...
My mistubishi WS-65713 73 inch tv's colours are off. There is mostly blue and green and some colours are non existent like red and yellow. What is the problem?
Sounds like a convergence problem which is common in these sets
This model uses two of the stk394-250 convergence output devices or chips.
Both would have to be replaced.
Mar 12, 2012 | Mitsubishi WS-65813 65" Rear Projection...
Mitsubishi WS-55613 55 color out
the problem is on the cables , look on the back of the cable box , if it is hd box the on ly thing you need to do is put the cables base on there colors green with green , red and blue , the other 2 are for video , but if it is normal box just put the yellow color with yelow on your box to your tv and the other to are audio
Jan 27, 2012 | Mitsubishi WS-55613 55" Rear Projection...
I have a Mitsubishi WS 55908 and is has lost its ability to show the color green. What could be the problem?
Hi jazz836,
You're unit has three color gun inside, the red/blue/green gun, since you haven't a green color, green gun is dead. This is caused by faulty resistor, tube, transistor, bad solder joints. If you have necessary tools and test instrument look first for bad solder joints in the neck board, re-solder all cold/dry joints, unplug then re-insert all cable connected. Test the parts in that board and also the tube.
If you can't do the job yourself I would advice you to look for a technician to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I have a 55 inch rear projection mitsubishi tv. it recently has started showing what looks to be white spots when viewed at a distance on a dark screen. when you look at it closely it actually is red green...
It is called Convergence. You have three CRTs. Red, blue, Green. When they are not aligned, you will see the individual colors. See if you can do some alignment in the users menu. Look for Converge or Convergence in the menu. Either under video or setup.
Mar 09, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have a 65 inch rear pojection ws-65315 tv from time to time the color is off everything is green and red.I tried to reset the color but it didn't work.
If you are using component cables, make sure the blue connector is fully in the jack at both ends of the cable.
- not much of a solution, but it did happen to me.
Oct 15, 2009 | Mitsubishi Televison & Video
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Colors are offset
You will need to install new convergence ICs if you need more info on this please let me know. Its a fairly easy repair.
Apr 10, 2008 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
