Question about Frigidaire GLTF1670A Front Load Washer
Not draining? the spin cycle does not seem to spin very fast and then it will not drain the water, I felt the hose at one time and it felt like it was coming up the drain hose then it just went back into the washer. Please help me, this is only 4 months old!
    President:
  • 1,314 Answers
Remove the drain hose from the stand pipe and vacuum the water out of the washer with a wet vac from the drain hose but because of the pillow this might not work in your case. Now remove the two screws on the front lower panel and pull the panel
in side you will see the drain pump if you did not have a shop vac go to the auto parts store and buy a pair of radiator hose clamps and clamp the hose line as close to the washer tub as possible.(but put down some towels as water always stays there) then pull the tub to pump hose by depressing the squeeze clamp(now while your at the auto parts id get a screw clamp to replace the spring clamp it makes putting the hose back on a lot easier)pull the hose off.Then pull the pump to drain hose off .Remove the two 5/16 in screws securing the pump to the washer base.Unplug the connector and remove the pump inspect the pump for foreign objects,broken or stripped impeller blades . if the impeller are stripped you will have to replace the pump then form the front of the washer take a piece of water hose with one end cut off and run it down the pump to drain end of the drain and reassemble the unit
Posted on Jan 22, 2008
Something is stuck under the auger,causing restriction. Whatever is stuck, its blocking the drain.
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
Oct 13, 2016 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Whirlpool Front Loading Washer Only Spins in Diagnostic Mode
replace the brushes in the motor _around 20 quid and usually the first thing to start messing up when the brushes get short is the fast spin _UNPLUG IT FIRST. you might also like to clean up the com with a bit of wet and dry
Oct 02, 2012 | Whirlpool Washing Machines
I still have wet close after spin cycle Why?
check the drain hose for any kinks in it,is it a top load or a front load washer and how old is it?the pump could be blocked with something or the tranny is bad.if it's a top load,set the timer on spin cycle,open the lid,start the spin and with a screw driver push down on the lid switch and see how the machine is spinning,if it's not spinning fast the tranny is bad.if the drain hose is stuck into a drain pipe pull it out and drain the water to see if the water is draining out good or partially draining,something could be in the pump or to much detergent,the washer can't pump out suds as fast as water then the suds turn back into water form again and the clothes are wet.
Apr 02, 2011 | Kenmore Washing Machines
My hoover washing machine will not spin and drain water at end of cycle. It starts the wash cycle it turns around but it does not fast spin at the end and drain the rinse water.
hello
Thnx for contactin fixya.
after goin through your question i felt There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is sliping or broken.
plzz follow these steps..
  1. Fill washer with water and wait for the timer to get to the drain mode.
  2. Unplug the washer from the electric outlet.
  3. Open the case, and disconnect the water hose from the outlet of the water pump.
  4. If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
  5. Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
  6. Reassemble hose from step 3.
  7. Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
  8. Reassemble washing machine case...you're done...
hope this will solve your problem.
for further queary plz do let us kno,we will b happy to help you.
all the best
regards
Jul 23, 2009 | Washing Machines
Wash cycle timing is way off.
Well, 1-1/2 hrs is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders....
 If it takes more time for drain or something , than it might be a concern............
However, to be on a safer side :) Lets troubleshoot
I would start by removing the hose off the pump that goes to the back wall of the washer and blow through it to make sure there are no obstructions. Also check the other hose from the tub to the pump. If there is, find and clear it. If not, read on. We need to make sure the transmission is working properly before going any further. When operating properly, this washer should drain all excess water (full load setting) in less than 180 seconds. That is the maximum neutral drain time for this particular washer. If you start the machine on a normal cycle with a 10 minute minimum agitate time, the transmission should not spin when it begins to drain. It is very important that you not disrupt the machine during this test, so use a small screwdriver to "trick" the lid switch, so you can have the lid open to see if it spins. If it doesn't spin while draining, then the transmission is okay. If it does begin spinning and draining at the same time, immediately reset for another 10 minutes of agitate and try again. You may have to run this test 1-5 times for an accurate neutral drain test. The most common failure of these transmissions is neutral drain failure. As I stated before, if the unit is spinning and draining at the same time, it won't be able to get rid of the water in time because the resistance of the tub trying to spin will slow down the motor which, in turn, slows down the pump. If the transmission doesn't spin while draining, see how long it takes to expell all the water; it should be less than 180 seconds. If it takes longer than that, there is some kind of restriction in the drain system. Anything from a kinked hose to a sock in the hose, or even a restricted house drain when the washer drain hose is sealed to the standpipe. If your washer drains to a floor drain, there should also be a siphon break in the drain line that may be bad or plugged. Let me know if you have further questions.
Thanks.
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining
check if anything is blocking the way of the drain pump ...else the drain impellor would have broken...
thankyou
Dec 05, 2008 | Washing Machines
Washer dryer sticks on j cycle does not spin or drain
check no foreign object stuck in pump impellor and that it turns freely. if that is ok then check continuity thro drain pump. if no muiltimeter, try connecting drain pump to mains direct to see it works
Aug 21, 2008 | Zanussi W1242W Front Load Washer
Water not draining
The belt may have failed due to the pump seizing up.
Remove the belt and turn the pump with your hand. If the pump seems hard to turn (should turn freely) replace the pump.
Jun 25, 2008 | Maytag SAV4655A Top Load Washer
Admiral washing machine MOdel AAV7000AWW On any spin will not drain 1st time through
is this machine induction motor or carbon brush if it is the inductin you need to be looking at the capacitor and if it is carbon brush then change them you will find them mounted each side of the motor and the capacitor will be @ the top under the lid near the pressure switch good luck
Jul 24, 2007 | Admiral AW22 Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
88 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
