Question about IBM ThinkPad R50e Notebook
Unlock laptop DVD
Hi, I have an IBM laptop with a MATSHITA UJDA760 DVD/CDRW. I have used up all the zone changes for the DVD and am now stuck on Zone 2. Is there a way to unlock the DVD so I can watch any zone? I'm not sure I trust all these websites that are selling codes and software programs. Thanks!
Re: unlock laptop DVD - IBM ThinkPad R50e Notebook PC Laptops
That is on ibmdotcom
Posted on Jul 28, 2008
Buy new laptop dude!!
Posted on Jul 09, 2008
    Problem Solver:
  • 17 Answers
Unless you can find patched firmware for your drive, then use someting like DVD Region and CSS free..
Posted on Jan 22, 2008
0 characters
3 Points
MATSHITA UJDA760 DVD/CDRW Drivers loaded succesfully but windows cannot find hardware device (Code 41)
* the electrical power is not reaching the drive -- if the drawer can open/close, then it is getting power;
* the "data" cable between the motherboard and the drive is not connected, or is broken;
* the electronics "inside" the drive are dead.
Take the laptop to a qualified computer-technician, for trouble-shooting, and for ordering/installing a replacement drive, because changing a CD-drive is not an "end-user" task.
Mar 02, 2010 | IBM ThinkPad R50e Notebook
How do I make my DVD/CD player (Matshita DVD-RAMUJ850S) zone free
you can download a plug-in but not sure where to find 1, sorry , but i will search around, cheers
Dec 12, 2009 | Fujitsu Siemens Fujitsu LIFEBOOK...
Will not read or write on cd-rw disc om matshita ujda745 dvd/cdrw
Some CD or DVD writes work with certain type of CD's or DVD's
Find out if your drive is compatible with CD-RW- or CD-RW+
If that is out of the way, and still same problem, then drive must have a physical damage and need replacement.
Please don't forget to rate if answer is helpful
Jun 28, 2009 | IBM PC Laptops
My Matshita UJDA 750 DVD/CDRW wont recognize a blank DVD discs. How ever it does read both CDs and DVDs and only burns CDs.... please help
Are you trying to burn a dvd? If so from the spec you gave in the problem description your drive will burn cds(CDRW) but will only play dvds(DVD). If it stated DVDRW then you would be able to burn DVDs as in the CDRW.
Mar 06, 2009 | Evesham Voyager 6400 Notebook
Matshita uj850 dvd dual layer..
On DVD Player as well as Computer DVDs there are different zones search for unlock code for your dvd play follow the instruction and it may work I have done this for my DVDs players connected to the TV as well as the computer ones
Jan 22, 2009 | Toshiba Satellite A135-S4527 Notebook
Restart from hibernation
go to the system tray and click once on the "Safely Remove Hardware Icon"
click on your dvd/cdrw to stop it. when it says it's safe, go ahead and remove the drive.
reinstall the drive and windows should automatically pick it up
also. go to --
Start -> Control Panel -> Power Options ->
Under Power Schemes set all the options under the ac power header to NEVER
unless you want it to hibernate, go to the hibernation tab and uncheck the enable hibernation box
go to the Advanced tab and under power buttons --
Close Lid = StandBy
Press Power Button = Shut Off
Press Sleep Button = StandBy
Oh and while you are there make sure the
always show icon in taskbar is checked, so you can keep an eye on your power
click apply and click ok and reboot
let me know if this works for ya
Dec 26, 2008 | IBM ThinkPad R40 2722 Notebook
My matshita UJDA760 dvd/cd rom wont eject
much like my dell inspirion 1100 the way i always fixed it was to simply push the button on the drive to eject and then slightly give the cd-drive a push to one side hope it helps
Nov 28, 2008 | PC Laptops
Check to make sure your sound settings in control panel are not: on mute or set to the minimum levels. Does sound work for everything else but your dvd player???
Oct 21, 2008 | PC Laptops
Zoned DVD Drive
I think you let it be the same( the last chance) and try to get this 2 software any of them
2.dvd regูion free
** this 2 program will make region zone free
*** check this 2 program out by typing the name at
Apr 19, 2008 | Toshiba Satellite M45-S355 Notebook
Dvd stuck on zone 1 when i am a zone 4
MMM impossible to unlock Yes it is inside your own time and mind set thats true for you !Anyway Region zoning does not protect copyright.!Newzealand is A Region Free regional code Free
so ridiculous restrictive practices that are coming to be regarded as
"normal".Thats what I would like to have you gies with this site to do to help !
stop this .
I know how to hack .to change the zones Any way.I have never recorded NEW
1. Empty the Disc Drawer
2. Press "Setup" on the remote
3. Press 1, 3, 6, 9, Left, Left, Left, Right (keypad)
4. "Version" will appear on the Menu, scroll down to this.
5. Once in "Version" go to "Region" and go across to the number and change
to "0" to Multi Region. Use the keypad to change the zones.
6. Then exit Version
7. Then exit Setup
THATS HOW I DID THE IMPOSIBLE I DONT KNOW WHAT THAT IS. I HAVE AN IQ OF 184 AND Having Aspergers Helps . I know about blue book 2012 and want to hack the Air force bace .Please reply.
Feb 12, 2008 | PC Laptops
IBM ThinkPad R50e Notebook Logo
531 people viewed this question
Top IBM PC Laptops Experts
John mullen
 Mike M
Mike M
Level 1 Expert
Are you an IBM PC Laptop Expert? Answer questions, earn points and help others
