Question about Epson Perfection 1200 Photo Flatbed Scanner
Any chance of a driver for Epson Perfection 1200 scanner with windows 7 64bit
    New Friend:
  • 3 Answers
RapidShare is dead.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
Posted on Jul 24, 2012
  • lamacrac
    lamacrac Oct 02, 2012
    Ml gracias
Windows 7 drivers for the Epson Perfection 1200U may be found at the following:
http://www.megaupload.com/?d=7BXHNC35
Have tested with own 1200U on Windows 7 64-bit. Works properly. It is based on the drivers for the Epson 2400. Minor changes to the .inf file allow it to work. Note that the Start button on the scanner also works. The software is somewhat different than the original. Another option is to buy software that enables the scanner.
Posted on Jan 04, 2010
  • 3 Answers
It's your lucky day!
I remember looking for hours for a driver for my Epson 1200 scanner back when I upgraded by dad to Vista 64 Bit, eventually I found one. Just today I upgraded him to Windows 7 64 bit and remembered I couldn't get it to work, luckily I was able to dig up the driver I used for Vista 64. Worked great in Windows 7.
I can't remember where I found it so I can't credit the person who made the driver unfortunately, however i've uploaded it to Rapidshare for you to download. Here is the link:
http://rapidshare.com/files/324940248/epsonScan_1.0_Per1200Win64eu.zip.html
Just open up the zip file and run the setup. :)
Hope this helps, Merry Christmas!
Posted on Dec 23, 2009
  • 526 Answers
The scanner is too old for epson to make a new driver. Its not cost effective.
thanks adi
Posted on Dec 16, 2009
3 Suggested Answers
SOURCE:
  • 127 Answers
SOURCE: no driver
GO TO WWW. DRIVERSGUIDE .COM SIGN UP FIRST THEN UNDER SEARCH TYPE IN THE MODEL AND DOWNLOAD
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: Epson Perfection 1200 Scanner Driver Needed for Windows 7
I posted this for another user but i'll post it here too,
Is there a driver for my Epson Perfection 1200U scanner which is compatible with Windows 10?
Its working perfectly with Epson 2400U drivers.
  • Download and install the Perfection 2400U drivers from Epson USA, version 3.04A http://www.epson.com/cgi-bin/Store/s...rm=OSF_W_10-64
  • Connect and turn on your scanner
  • Run Device Manager
  • The Perfection 1200U will be shown under under Other Devices
  • Select Update Driver
  • Choose 'Browse my computer for driver software"
  • Choose 'Let me pick from a list of device drivers on my computer'
  • UNCHECK the 'Show compatible hardware'
  • Click on 'Epson' in the Manufacturer box, and the scroll down through model until you find "Epson Perfection 2400', and choose that, and press Next
  • Ignore the 'Update Driver warning - choose 'Yes'; to continue to install.
  • The Perfection 2400 will now be shown in Device Manager. Note that the Perfection 1200 will still be shown under Devices & Printers
  • Run Epson Scan and test the scanner. You may need to log out and log in again for program to work
Nov 03, 2016 | Epson Perfection 1200U USB Flatbed Scanner
I need a driver for my epson 1200u photo scanner. my windows system is 64 bit, window 7. can you help?
should be doing.
Simple as pie.
Dec 09, 2010 | Epson Perfection 1200 Photo Flatbed...
I can not install my Epson scanner perfection 1200 photo on my laptop vista 32bits OS?
It all depends on what driver you have, it would probably be best if you went to the Epson web site, followed links for support and downloads and downloaded the latest driver for you scanner/operating system.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14557&prodoid=8161&infoType=Downloads&platform=Windows
When I say that, I've just had a look and it maybe the case that this scanner isn't supported for Vista and beyond.
My only other suggestion to use their contact us link and ask them.
Oct 29, 2010 | Epson Perfection 1200 Photo Flatbed...
I want to upgrade my Epson Perfection 1200 Photo flatbed scanner so I can use it in Windows XP
Are you talking normal XP or something more specialist...If normal just download the twain driver from the epson site. I cannot get the copy utility to work but the twain give you the functionality to scan. Following the other threads here I have been able to get this scanner two work even better on 64bit Vista
Jan 05, 2010 | Epson Perfection 1200 Photo Flatbed...
No driver
Jun 26, 2009 | Epson Perfection 1200 Photo Flatbed...
Epson scanner perfection 1200u photo
The driver listed on the web for 2K is compatible with XP.
1) Go to the website http://support.epson.com
2) Under the SCANNERS heading select Epson Perfection Series and then your scanner model.
3) Under the Drivers & Downloads section select Windows. Download the most current driver for your Windows operating system.
4) Follow prompts through survey and license agreement. Choose to SAVE this file to your DESKTOP.
5) When the download is complete, double-click on the Epson icon on the desktop. This will automatically extract the files and begin the SETUP.
6) Follow the prompts to install the scanner, and click on FINISH when prompted.
7) At this point reconnect the scanner to the computer.
8) You will see an ADD NEW HARDWARE WIZARD. Make sure INSTALL THE SOFTWARE AUTOMATICALLY (Recommended) is checked and click NEXT.
9) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
10) Your scanner is now installed. Restart your computer before testing.
Dec 03, 2007 | Epson Perfection 1200 Photo Flatbed...
Epson Perfection 1200 Photo Flatbed Scanner Logo
1,764 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
