Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung SP43T5HP unit keeps power cycling
Hi
A couple of nights ago while my parents were watchign TV the unit decided to switch off and then seem to go into a "power cycling" loop. They could not stop it using the remote, the only way was to either unplug it from the wall or use the power button on the unit itself.
I had a look yesterday and when I pressed the power button on the unit again it didn't go into standby mode, it actually tried to switch itself on, the "standby/timer/power" (it's the one light) light flashed red 5 times then on the 6th time it went green, I heard sound for a second with no picture, then the unit would start the power cycle loop again.
I took out the batteries out of the remote (just in case that was soemhow causing it) but that didn't help either. At this moment I have unplugged the unit from the wall and will re-plug it in after 24 hours to see if that helps.
the manual for the unit doesn't have any troubleshooting steps for light sequences, etc so I can't do much. I am guessing it is the lamp but I would have thought the tv would behave differently to this.
Does anybody know what's going on?
Thanks
  • Anonymous Mar 03, 2008
    on off cycle continues. green lamp light,then off red light- cycles three times then it turns all lights on. two green and one red looks like a monster smiling at you
  • Dazza84 Apr 19, 2008
    Same model and problem. I was told that when it went. The picture showed in green and black/grey so I guess if its a lamp it would be the red one. The sound was fine when this happened. Thats until it was turned off. now when you turn it on it has this problem. Does anyone know which bulb is the red one.
I had this problem in December...ultimately it was a problem with the digital board (the tech tried a new light engine first, but that didn't fix the issue). Pay attention to the lights on the front...but if the picture doesn't come up at all and the power just cycles, your issue may be bigger than just the lamp.
Posted on Feb 12, 2008
You must change the bulb. It is worn out.
Posted on Feb 04, 2008
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
TV doesnt turn on. It cycles thru a couple of times and then stops. 2 green lights and 1 red light flashing on front panel. replace lamp about a year ago
Check the filter and see if this is clogged. If so clean and reset. The processor of the projector seems to switch off power due a feedback error and must be traced.
If the lamp holder is loose fitting, if the lamp has failed or if there is problems in the power section this can trip.
Aug 08, 2011 | Samsung Televison & Video
Samsung HL-S5679 turns on and off
I had the same issue about a year ago and they replaced the power supply on the unit. Just started doing the same thing again now on my end as well. 1 more repair after this and I can lemon law it on the warranty that I took out on it.
Oct 21, 2009 | Samsung DLP HL-P5663W 56" TV
No Power
you could have gotten hit by a surege hope you had a surge protector, if you did just reset the breaker on it
Jul 25, 2008 | Samsung HLN617W 61" Rear Projection HDTV
No power, picture or sound
Contacted Sears and they are sending a Samsung Tech to fix my TV. Others had no luck getting a response. Sears did not argue about Warranty.
Jul 09, 2008 | Samsung TXN2775HF 27" TV
Water filling then emptying again right away
Take the cover off, as you face unit on right side follow the vacum hose to two presure switches. Tap on them lightly with a the handle of screw drive. fix my unit three months ago still working. The problem is the presure switch.
Dec 08, 2007 | Danby 22 in. DDW396 Free-standing...
Screen is filled with a circular Red/Green/Blue pattern
The problem will be with the de-gausing circuit, this de-magnetises the tube when the set is switched on from cold, this is a fault you will need to get an engineer to look at ie, not a D.I.Y repair.
Mar 05, 2007 | Samsung TXR2675WH TV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
326 people viewed this question
Jerry Greenberg
Jerry Greenberg
