Question about Whirlpool LSR6232J Top Load Washer
Mad dog kit? Bird dog kit? Some kinda dog or somthin'?
Have a friend who was a former repairman. My agitator wasn't agitating, so I took it apart. He recommended some kind of dogs, but I can't figure out what model I have. It says Whirlpool Stylemaster 4217141 Heavy Duty Extra Large capacity +. Anyone help me with figuring out my model? Thanks very much in advance.
  • 3 more comments
  • Greg Spencer Jan 22, 2008
    Yes, it does spin, and roughly 8 years old? Maybe 10?
  • Greg Spencer Jan 25, 2008
    Thank you JSRock! I really appreciate you taking the time to respond. Folks like you make the world go 'round. Will be in touch when the parts come in. Thank you again!
  • notaplumber May 11, 2010
    Hello Mr. jsrock516. Here is my problem. I have a Whirlpool washer serial # LSR6332KQO, and when it spins, it does not spin fast enough?? When done the clothes are still wet. Please help if you can. Thank-You Sir.
  • robert samples May 11, 2010
    sorry but i need to understand the promblem for best advice when it filled you could hear the motor running but it wasnt agitating and if you give me the serial number off the washer i can help with the age
    close the lid and see if it spins and how old is the unit
  • 5,911 Answers
Your model number will be located somewhere around your tub opening under the lid. The parts you are looking for are called "agitator dogs" (yes, there is such a thing). There are four of them located under the agitator cap that help grip the agitator shaft when turning. This causes the agitator to crank in one direction during the wash cycle. The part number for the entire repair kit is 2744 and costs $16.80. This includes all the washers and bushings as well as the dogs. If you just want to purchase the dogs, the part number is 3109 and costs $5.20. For a little more, the entire kit would be a better recommendation. You can get everything you need at repairclinic.com. If you cannot locate your model number, type in the brand name of your washer (i.e., Whirlpool Stylemaster Washer) in the "Search" window and you will find what you need. These parts are the same identical parts that your major appliance service companies use, but cost much less (I should know, I used to work for one of them). Let me know if you decide to repair on your own and I can give you follow-up advice on how to take the agitator apart and replace the parts you need.
Posted on Jan 25, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 25, 2008
    Glad to have been of some help to you. Post back with comments when you receive your parts. Your comments will be sent to my email account and I will receive a notification.
Tip
Whirlpool: How to replace the dog kit of direct drive washers
How to replace the dog kit in agitator
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16" bolt and lift the agitator out of the washer. Separate the upper and lower pieces of the agitator and replace the dog kit inside the upper part of the agitator. Make sure the 4 pieces remain in place while putting the agitator back together.
on Feb 12, 2010 | Washing Machines
Agitator not working
Hi, This agitator is a 2 piece agitator. Can you see if the lower half on the agitator is working properly? If the lower part is working and the top is not, you will need to change the agitator dogs. If neither half are working, you might be having transmission issues.
To change the dog kit, re,ove the top cap on the agitator and locate a 7/16" bolt. Remove the bolt and the agitator will lift out. Pull the agitator apart and the dogs are 4 small plastic pieces inside the top half of the agitator.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Top of agitator does not agitate with lower agitator.(dual agitation) whirlpool model LA3860XW00
You will need to replace the Dogs. Take cap off of the center of the agitater, take bolt out of center and pull agitater up and off. Pull two pieces apart. There are four dogs that catch on gear teeth inside your agitater. The four dogs come in a hit, sometimes with a couple other pieces. Has to do with which model you have) replace these four and any other pieces that come in the kit you order. This will fix your problem.
Please rate solution
Aug 31, 2009 | Whirlpool Washing Machines
Whirlpool ultimate care II - agitator makes a horrible noise
You may have worn agitator dogs, causing the upper portion of the agitator (called the "auger") to slip. Or, you could have a loose agitator bolt. The following link explains how to replace the dogs (if necessary) and how to access the bolt:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
If you need to replace the dogs, the part number is included. You can purchase them for about $5 at appliancepartspros.com. For a little more, you can purchase the entire agitator drive replacement kit. Look for it under the "Agitator" parts section. You can also reference the helpful exploded view diagrams the site offers for assistance.
NOTE: When tightening the agitator bolt make sure you do not overtighten. This may cause damage to the agitator, or restrict its movement. Tighten until snug.
This repair should take about 10-15 minutes and does not require special tools, a repairman, or a lot of money. If you still require assistance, please let me know. I hope this helps you.
Aug 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bottom of agitator works, top half does not. Dogs appear to be worn. How do you fix this?
remove the agitator by removing the agitator bolt in the center then the pieces will all come apart, don't just buy the dogs, get the whole cam kit, it doesn't cost much more and it comes with all the replacement parts for the internal agitator
Aug 06, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Series 80 Washer, Model 20852 - Agitator not turning well, making noise
Hi, If the washer spins properly but the agitator does not work, it could be the dog kit needs replaced. If the washer does not agitate or spin, it is probably the coupler.
Put the washer in wash cycle with no laundry in it and see if the lower prt of the agitator moves. If the agitator moves, try and hold the upper half of the agitator and see if it will only move one direction.The agitaor dog kit is designed to only let the top part of the agiator to grab one way. When they go bad, they can make some noise.
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16” bolt and lift the agitator out of the washer. Separate the 2 halfs of the agitator and replace the dog kit inside the upper part of the agitator.
Thanks
Vic
Jul 17, 2009 | Washing Machines
Washer does spin but barely agitates
It sounds like the agitator dogs are worn.
To remove the agitator, pry off the agitator cap and remove the bolt that holds down the agitator. With the bolt out pull up on the top section of the agitator (auger) to remove it. Underneath the auger you should see 4 small white or beige plastic gears (dogs). . Replace those and it should be ok.
The part number is 80040
Let me know if you need more assistance.
Apr 08, 2009 | Kenmore Washing Machines
Model # 110.29852991
Follow these simple instructions:
Remove the agitator from the washer.
Sit the agitator on the floor.
Grab the top part and hold down the base with your feet.
Yank the 2 sections apart. Get dog kit #80040
Replace new dogs in cam and snap the 2 units back together without breaking the positioning tabs on the bottom portion.
Ease the agitator back into the washer being careful not to seperate the two parts while pushing down onto the tranny spline. Do not overtighten that bolt with the fancy washer in it.
That is all Jim. Should your mission fail be advised that all knowledge of your mission will be disavowed, good luck Jim. This message will self destruct in 2 more beers.
Jan 08, 2009 | Kenmore 22422 Top Load Washer
Trying to connect agitator without dogs getting out of place
I thought the two parts would snap/connect together. They don't. Put the agitator on upside down over the "dogs" and their connector. Holding that together put the top agitator over the bottom. Carefully put over the metal connector inside the washer and connect the bult. The bult is what holds the pieces together.
To take apart initially I had to use a socket set with a long extension and a pipe over the racket handle to get enough torque to loosen the bult
Dec 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool LSR6232J Top Load Washer Logo
612 people viewed this question
Dan Webster
Dan Webster
Sal De
